How do you like your 17" Toyo Proxes?
Discussion in 'Gen 3 Prius Main Forum' started by socal13, Jul 27, 2013.
  1. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    I previously had a 2010 III with 15" Yokohamas and the handling always felt loosey goosey on the freeway. The Toyo Proxes handle much better... more stable, solid feeling on highway and on curves, turns. I know some say they are supposed to have sidewall weakness and prone to blowouts. I wonder if that's true.
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I got about 3 years & 60000 miles out of my OEM set. tp was max sidewall pressure from Day 1. No handling problems even during rally and autocross. I suspect you are more likely going to have an adventure with 34psi in them.
  3. socal13
    267
    Altadena CA
    I'm putting 40 f 38 r in them. They seem like good tires so far. 60k miles sounds great.
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I have 20K on mine. No problems yet. Noisey and rough riding. I run 38/36.
  5. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    I notice that once you go up in PSI(40), road noise increases substantially. I had them at 35 and they seemed a lot quieter on the freeway. In regards to handling and road feel, I give them a 8 out of 10. I think the limited factor has not been the tires but suspension.
