HID Lights for 2010+ Prius
Discussion in 'Private Sales' started by NASCAR Mike, Jul 29, 2013.
  1. NASCAR Mike
    NASCAR Mike Senior Member
    83
    Richmond VA
    I sold my 2010 Prius and I removed the aftermarket HID lights from the car.
    This kit is a true plug and play style. The wires plug into your factory wiring harness and gives you much better lighting. Bulb color is 5000k, true white color. No bluish tones.
    Bought new for $150. Selling for $55 shipped to your door.
    H11 bulbs
  2. Air_Boss
    Air_Boss Senior Member
    4,161
    1,166
    New Yawk
    H-what lamps?
  3. NASCAR Mike
    83
    Richmond VA
    They are H11 bulbs
  4. Air_Boss
    4,161
    1,166
    New Yawk
    Thanks. What wattage ballasts, and are they "slim"?
  5. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Those look like full size ballasts.
  6. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    How long were they in the car, and how many minutes/hours per day were they typically used?
    SCH-I535
  7. NASCAR Mike
    83
    Richmond VA
    They are not slim ballasts.
    They were in the car for about 2 years. I drove the car about 20,000 miles in that period before I sold the car.
    I can't give you a honest answer how many hours are on the bulbs. I can tell you I have the same system (different bulbs) in my Ford Excursion with 178,000 miles on it and I still have the original bulbs. I think HID bulbs last 4000 hours but don't take my word on that.
  8. NASCAR Mike
    83
    Richmond VA
  9. nklb
    nklb Member
    111
    Do these have any auto-leveling mechanism? IIRC it is illegal to use HID lights on the public roads without a cutoff for a certain height of projection.
  10. NASCAR Mike
    83
    Richmond VA
    There is no auto leveling mechanism with these HID or any that I know of.
    I will tell you that the Prius factory headlights are perfect for HID's. They cutoff very sharply and not once did anyone ever flash their high beams at me.
    The great thing about these HID's is that they improved nighttime visibility dramatically. They are so much better than the halogens.
  11. burstaneurysm
    469
    144
    Chicago, IL
    It's technically illegal to run HID bulbs on any car that did not ship from the factory with them.
    That being said, as long as you consider the cutoff height (which is adjustable on the headlight bucket) and don't have a color that is too blue/non-white, you shouldn't have a problem.
    Again, it is technically illegal, but it's rarely enforced.
  12. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    The leveling mechanism is part of the car. It would be hard to sell in a kit. A car with incandescent headlights will not have a leveler.
    I believe you are right.
  13. NASCAR Mike
    83
    Richmond VA
    Sold. Thanks all.
