Those with FRS/BRZ wheels...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by larryt1026, Jul 31, 2013.
  1. larryt1026
    larryt1026 Junior Member
    61
    Hello!
    Those with FRS/BRZ wheels, did you have to run spacers? Or are they a direct swap. Thanks!
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Everyone says you need spacers or you have to grind off 1/16 to 1/8 inch of the caliper.
  3. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    In addition to the clearance issue. Not sure if the hub bore in the FRS/BRZ wheels are the same.
    DROIDX ? 2
