Engines
Discussion in 'Gen 3 Prius Main Forum' started by Coldsteel, Aug 1, 2013.
  1. Coldsteel
    Coldsteel New Member
    Fort Worth, Texas
    Are the engines the same in the 2013 Prius with just changes to options such as seats,stereos between models
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Yes, 2013 uses the same 1.8L as 2010+. Also, the engine in a 2013 two is the same as what is found in a 2013 three, four and five.
  3. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    The engine in the Lexus CT200H is the same as well. They just have different programming on the ECU. Not sure if they changed the final drive ratio as well, like they did with the Prius v.
    SCH-I535
  4. jgilliam1955
    368
    102
    Williamsburg, Virginia
    What they said...
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Except the Prius C, which uses a 1500cc engine.
  6. g4_power
    g4_power Junior Member
    105
    I
    If I remember correctly, the mpg of a Prius C isn't any better than the Prius Lift Back, one would think that a smaller engine would yield better mpg.
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    The c does better in the city, but give it all back on the highway, to yield the same over all MPG. Small engine is more efficient in the city, but less on the highway. It is a compromising game...
    g4_power likes this.
