  1. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Yep.
  2. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Installed high power LED head light bulbs.
    ePrius and Burna J like this.
  3. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
  4. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    installed blind spot mirrors
  5. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    yes with a dimmer.
  6. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    awesome
    LG-MS870 ? 2
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Do you have any pics of the bulb?
  8. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    sfv41901 likes this.
  9. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Any special ballast or harness required? I like the intensity of these.
  10. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    comes with ballast. The set up is just like an HID kit.
  11. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    SCH-I535
    Details (watts, lumens, etc) please, and links. :)
  12. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    Here is a link
  13. xliderider
    8,033
    3,211
    Honolulu, HI
    Thanks, but can't see it on my smartphone. :(
    Can you post a simple weblink? :)
    Edit: NVM, I was able to get to it by manually searching using the item number.
    SCH-I535
  14. Newpriusdanni
    Newpriusdanni New Member
    27
    I put a hand shaped peace sign sticker and a purple regular peace sign with daisies on it in the little side front windows !!!!
  15. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Even copying and pasting a simple weblink now gets automatically converted into the annoying widget that we can't see on our smartphones. It didn't used to be that way. Annoying, I know.
  16. El Dobro
    El Dobro A Member
    7,071
    3,258
    Today, I greased up the brake pads so they don't clatter and I glued the parts of the rh mirror back on until the replacement shows up.
  17. Vitaliy
    Vitaliy Junior Member
    47
    It was busy weekend, but here is the result.
    Jk, but took my Prius for a trip to Temecula, and ran across this . How cool is that, huh?
  18. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    You can go to ebay and seller is RSI LED lighting.
  19. xliderider
    8,033
    3,211
    Honolulu, HI
    These are Cree LEDs, so they're typically 5w each, and there's 2 per light. So only 10w each light. Description says they're 20w, so they must be talking about both sides total.
    They claim they're 2x brighter than H11 bulbs at 1900 lumens, but H11 bulbs are about 1350 lumens, so kind of shaky math being used. :(
    It's good to see that a small cooling fan is mounted on the base of each bulb because heat is bad for these SMD LEDs. 30k hour service life is pretty optimistic considering the application, and the warm environment in the engine compartment.
    Please review your impressions Dawit after driving around with these for a while. :)
    SCH-I535
  20. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    I have been driving with these for about a week now. They produce a much brighter light than the HIDs I had. So far haven't had any problems.
