Fuel Economy Question
Discussion in 'Gen 3 Prius Fuel Economy' started by Sumedha, Aug 3, 2013.
  1. Sumedha
    Sumedha Junior Member
    52
    Colombo, Sri Lanka
    I am from Sri Lanka and I recently brought down a Prius from Japan. During the first week, I experienced amazing mileage around 30 kmpl. I am in to the third week now and now I am getting a 20-23 kmpl mileage.
    I noticed the difference after I got the Prius serviced through Toyota (Local Dealer).They did change the engine fluid. All other ones they topped up.
    What could be the reason for this from your experience ? Can change of engine fluid or transmission fluid can do a difference ?
    51,053
    check the oil level on the dipstick. they sometimes overfill and this can lead to poor mileage. also, check tyre pressure, they sometimes let pressure out of tyres. all the best!(y)
    bwilson4web likes this.
  3. retired4999
    2,652
    625
    Eau Claire, Wi.
    Dealers change tyres air pressure for a softer ride, check tyres. I run 42 psi front and 40 psi rear. Do not go higher than max psi on the side wall of the tyre.
  4. Former Member 68813
    3,524
    983
    US
    They could have put high viscosity oil in. It will make a difference in short trip driving and less so in high speed driving.
  5. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Oil should be 0W20 and not over filled. Tire pressure should be close to 40 PSI.
    You'll need to find out what oil they used and the viscosity of that oil. Anything other than 0W20
    will affect your MPG's. Always make sure the oil level is at the correct level on the dipstick.
    They may have reduced the tire pressure too. Get a gauge and set it to 40 PSI and check it at least every month.
  6. bwilson4web
    15,992
    If you have the time and can afford it, you might consider doing a series of 'benchmark' runs at fixed, cruise control managed speeds, both directions, on a flat road, say 16 km long. Having a set of different mileage vs speed data points, we can then understand what is going on. Be sure to record the temperature on these runs as air density has an effect at higher speeds. The goal is to make a chart looking something like:
  7. Sumedha
    52
    Colombo, Sri Lanka
    I called my local dealer and they have confirmed (as in the invoice) that they are using the engine fluid 10W-40 . When ask them about 0W20, what they said was they are not bringing it down and 10W-40 is what they use for all petrol based engine cars.
    Can someone please send me an email address to contact Toyota ? I just need to clear this out from them and escalate this to my local dealer.
  8. Drdiesel
    585
    152
    Monterey CA
    That's the wrong oil. You need 0W20 synthetic for your Prius. Change it ASAP.
  9. Sumedha
    52
    Colombo, Sri Lanka
    Local Toyota dealer says this is what they recommend. Plus, they do not have 0W-20.
    That's why I wanted to escalate this to Toyota global. If the local dealer is going against their recommendation, there should be a valid reason for it.
  10. Drdiesel
    585
    152
    Monterey CA
    Here's the data sheet for your car.
  11. Drdiesel
    585
    152
    Monterey CA
    Toyota dealers aren't bound by Toyota. They're independently owned. Your dealer is a JERK.
    Go to the auto parts store and buy the proper oil and filter and have an independent shop change your oil before you have possible engine damage..
  12. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Here's Toyota Lanka's fluids page. It shows 10W-30 regular oil and what looks like 5W-30 synthetic.
    As DrD says, if you want 0W-20 you'll probably have to find an independent shop. Is this one near you?
  13. Former Member 68813
    3,524
    983
    US
    People, relax. 0W20 is required in USA only due to CAFE regulations. Outside USA up to 20W50 is fine (depending on ambient temps).
    Sumedha
    What is your driving pattern?
  14. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Erm disagree with you there. It's 0w20 in all the major markets too.
    I posted very early gen3 adverse mpg experience when my car was filled with 5w30. The dealers assumed the same oil as goes in the gen2 Prius would be fine in the gen3. Wrong. The mpg's dropped and getting over 50 mpg UK was very difficult and over 60 mpg UK was impossible. Performance at top end was also restricted slightly. Once 0w20 oil was used again the car almost instantly went back to the original high mpg's.
    Not sure how hard 0w20 oil will be to source in Sri Lanka as it's quite rare here despite being required in the Toyota hybrids (Yaris, Auris, Prius) and many other Toyotas with start stop technology.
    Maybe ship over 5 litres of Toyota 0w20 oil and change yours to it and see if mpg's increase. It's not cheap oil but it's a small price to pay for such a car.
  15. Former Member 68813
    3,524
    983
    US
    There is a difference between recommended and required. There is no question that 0W20 will be best for fuel economy. I was the first one in this thread to suggest checking oil viscosity.
    Related thread: Would you use 5W40 for your Prius C? | PriusChat
  16. Sumedha
    52
    Colombo, Sri Lanka
    This is close by. I need to call them to see whether they have 0W-20. Thanks mate for getting this.
  17. Sumedha
    52
    Colombo, Sri Lanka
    0W-20, is this a fully synthetic oil or does it have varieties ?
  18. GasperG
    GasperG Senior Member
    1,168
    599
    Slovenia
    2018 Prius
    From my experience 5W-40 was responsible for at least 5% worse fuel economy (see my signature and records for 2011), 10W-40 in your warm climate should have comparable results.
    A drop from 30 to 20-23 kpl is a little exaggerated to be a oil fault alone. Maybe it's the driving style or something else.
  19. Drdiesel
    585
    152
    Monterey CA
    100% synthetic.
  20. Sumedha
    52
    Colombo, Sri Lanka
    I've checked many places and it seems like 0W-20 is not available in this market. However, I found that Mobil has a fully synthetic 0W-40. Can this be a suitable replacement ?
    Also now that Toyota has filled my engine with 10W-40, can I return back to a fully synthetic oil ? I think the 10W-40 they've filled in may not be fully synthetic.
    Toyota and Mobil both offers a 3W-30 a fully synthetic formulation as well. could that be better than 0W-40 ?
    I need your expertise.
