Watching the sun circle the pole
Discussion in 'Environmental Discussion' started by bwilson4web, Jul 30, 2013.
  1. bwilson4web
    16,222
    The time lapse shows the sun circling the pole . . . something I've read about but never seen before.
    fuzzy1 likes this.
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    I have seen this phenomena twice during the two 6-month stints I've spent at McMurdo Station Antarctica. Basically, if you are at a latitude higher than 66 degrees North or South the sun becomes circumpolar during the summer in the north and during the northern hemisphere winter in the south. The further north or south you are, the longer the period of uninterrupted sunlight. More info here
  3. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Ive heard that the effect of albedo loss at the poles is exaggerated.
    If the sun is low on the horizon ,much light caroms off the surface of water.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    Exaggerated in a modeling sense? I know they have to tweak various values to get the global heat budget to work in climate models. But yes, angle of incidence is everything.
  5. tochatihu
    tochatihu Senior Member
    9,788
    3,772
    Kunming Yunnan China
    2001 Prius
    Reflectivity as measured from satellites
    Albedo
    provide albedo and angle of incidence information. So this is surely not a case where climate models are missing some obvious detail that 'somebody has heard ...'
    Some might know the name of Steve Squyres? Slightly famous for managing two Martian Rovers? He published on this stuff in 1982. Falls pretty well in the category of 'known and understood'.
    The title of the thread reminds me that some evidence exists that the Earth circles the Sun. Not the other way around.
    ftl and bwilson4web like this.
  6. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    "Albedo change in the Arctic threatens to cause runaway global warming"
    Arctic News: Albedo change in the Arctic threatens to cause runaway global warming
    Were all gonna die due to lack of albedo causing catastrophe!!!
    2012 had low Arctic albedo.
    But 2013 Artic ice is rapidly gaining volume.
    Albedo loss isnt causing the end of the world.
    Albedo loss is having negligible effect on increasing ice volume or lower sea surface temps .
    Run Run Run RunAway.
  7. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    BTW Arctic ice volume is gaining rapidly , in spite of continually rising CO2 levels and loss of albedo.
    Strange gas that causes ice loss and now ,ice gain.
    CO2 also causes record high levels of Antarctic ice presently .
  8. bwilson4web
    16,222
    What a silly thing to claim:
    Oh I see. You think we need to wait until the end of August, fool.
    ftl likes this.
  9. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Its an increase of ice from 2012 .
    While Co2 is continually rising and albedo is lowered..
    Explain how CO2 causes this?
    Whos the FOOL?
  10. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    BTW dont call me a fool.
    Unless you have something intelligent to add.
    Which is unlikely,judging from your previous posts.
  11. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    For that matter explain how the Antarctic is at record high ice volume with record high CO2?
    If you cant explain that ,then you are obviously the "fool"
  12. bwilson4web
    16,222
    Have your way:
    You're the liar:
    Your choice, liar.
  13. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    OMG Im debating a mentally impaired person .
    Touche, you win the special debate award.
  14. bwilson4web
    16,222
    Works for me:
    The Arctic ice is thinner and no lie you post changes that observation. It is running thinner than the average and only last year did it set records for the thinnest. Soon enough, it will bust that record, if not this year in another. You're toast, son.
  15. icarus
    icarus Senior Member
    4,884
    976
    earth
    So Mojo, do you have any citation for your claim that Arctic (and
    antarctic) ice is increasing?
    Even your own provided link re: Albedo seems to confirm the opposite!
    Icarus
  16. AzWxGuy
    AzWxGuy Weather Guy
    1,055
    538
    Tucson, AZ
    2021 Prius
    Goodness, this is dangerous "flaming" ground to be walking upon ... Quick, back to my Gen II forum ...
  17. bwilson4web
    16,222
    Relax, we have one gadfly. Credible posts by credible folks are always welcome.
    One tell is that serious folks still take correction such as my recent education about wind shear at lower levels. I was aware of jetstream effects but hadn't really considered lower level, wind shear and learned that NOAA has quantitative numbers that combine the independent variables to calculate a risk-factor for tornado formation. Fascinating stuff.
  18. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
  19. icarus
    4,884
    976
    earth
    Mojo,
    I have read (and scanned) through dozens of page from the National snow and ice data center site you note, and NOWHERE can I find a chart that looks Ike yours! Either you have done some pretty thourough cherry picking, or you have been hoodwinked by a made to look alike, or you are attempting to make it up.
    What I IDID find on the site, was overwhelming evidence of the trend to lower summer ice levels in the Arctic.
    On a side note, listening to CBC the other day, I heard a story about a record number of ships making trans arctic passage this season, primarily using the N.E Passage over Russia.
    Icarus
  20. bwilson4web
    16,222
    LOL! He simply changes to Antarctic ice cover as if we might not notice.
    If I remember correctly, there is a satellite mission that makes an inventory of the global ice cover including Greenland. I don't remember the name but I'm sure Mr. Google does.
