If you like your PiP, then you would also like..
Discussion in 'Fred's House of Pancakes' started by gas zipper, Aug 9, 2013.
  1. gas zipper
    gas zipper New Member
    battery powered grass mower. I have about 1/3 acre of grass and it takes less than 0.5 KWH to mow the entire lawn. In $$$ terms, that's about 7 cents. It used to cost me $1.50 in gas to mow. Other benefits includes no oil needed and no spark plugs to change. The noise level is much lower and very little vibration. The mower itself is super light so you will not need the self-propel option
    JMD likes this.
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    What brand do you have?
  3. mrbigh
    3,686
    699
    Long Island, NY
    Brand and model#? :D
  4. gas zipper
    I currently have the GreenWorx 19 inch blade, 40volt. Make sure whatever you decide to buy, get the one with Lithium battery. The lead acid battery is heavy. You'll probably pay more for lithium but it's worth it.
    I got mine from Lowes. GreenWorx 40v lithium, 19 inch blade. I haven't tried other brands so I don't know if this one is the best. But for me, it's working great. Whatever you buy, get the lithium battery ones.
    mrbigh and JMD like this.
  5. JMD
    3,779
    1,282
    Thx for the info.
    gas zipper likes this.
  6. mrbigh
    3,686
    699
    Long Island, NY
    DITTO
  7. Trollbait
    12,446
    I have a Fiskers reel mower. I don't even use electricity.
    walterm likes this.
  8. gas zipper
    Some people use goats to mow. After a few years, they could also enjoy their meat.
    amm0bob likes this.
  9. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    We have one of these...
    Battery powered... it's just able to cut the front and back yard before the battery gives out.
  10. gas zipper
    The Greenworks comes with two batteries. One big one and one smaller ones. Most of the time, I mow the front on one day and the back another day.
    usbseawolf2000 and amm0bob like this.
  11. bisco
    51,561
    that's a lot of grass! how long does it take?
  12. gas zipper
    If I bag the grass, it's about an hour since I had to spend more time emptying the bag. Normally, it takes about 45 minutes to do the entire yard. Since the electric mower is super light, it's not a bad 45 minutes. I usually mow when the sun is still out, that's why I split the chore into 2 days. I can't stand the heat.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I have used the corded one and it is a pain to manage the cable. This one sounds like a winner.
  14. gas zipper
    Thanks. I'm actually quite surprised how well it works considering it's powered by a battery. I was expecting it to be under powered but that's not the case. It also has a built-in sensor for monitoring motor speed. If I were mowing thicker grass, it would automatically draw more power to do the job. Otherwise, it would run at a normal speed which use less power.
    usbseawolf2000 likes this.
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    That's a really good feature. It'll extend the usage time or decrease the battery size to make it lighter.
  16. bisco
    51,561
    i hear you brother, that's why i stay out of the kitchen.:p
  17. El Dobro
    El Dobro A Member
    7,079
    3,259
    I have a Sears Craftsman electric mower that still starts the first time, every time for the past 40 years. :p
  18. gas zipper
    If I had a small yard, I would have gotten an electric mower long time ago. The cord is a pain even just for trimmer.
  19. El Dobro
    El Dobro A Member
    7,079
    3,259
    After all this time, I don't even notice the cord. I start close to the plug and zig-zag away from it.
  20. gas zipper
    My options were buy the gas mower and my wife would help with the mower or buy the electric mower and get no help. I didn't have to think too long to decide
