Induction Upgrade
Discussion in 'Gen 3 Prius Accessories and Modifications' started by BigPete, Mar 16, 2013.
  1. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    Here off eBay from here in UK, cheapest yr find it aswell.
    http://bit.ly/13aMIFB
    I contacted Samco UK direct ages ago and this company contacted me, they are Samco's main UK dealer.
  2. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    Yeah but pricey for you guys buying from UK as exchange rate is against you, but when we buy from USA it's a bargin!!!
  3. edwardob
    edwardob Member
    227
    33
    ireland
    still a 165 dollars plus post for a whistle......
  4. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    If Samco USA make it yr get it for cheaper, probably be around $100, the exchange rate doesn't help you guys over there in USA.
  5. edwardob
    edwardob Member
    227
    33
    ireland
    you could replace middle part on original with straight pipe...[perhaps household pipe] for same effect....unless of course it's purely for pimpimg
  6. peterjmc
    917
    189
    Clarksburg, MD
    I'm sure this is strictly for pimping
    - P
  7. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I believe Cusco STB is aluminum and has only the end plates in Cusco blue. Why don't you get the Tanabe STB powdercoated in blue by a local shop? Either way, it'll look much better than the mismatched combo.
  8. ecowhipz
    ecowhipz New Member
    Samco is a great company that does tons of silicone piping for all types of vehicles. When I had my shop we used them extensively for forced induction applications. That piece is made to hold some boost in case anyone gets adventurous... I think the real gain, if any, will be had in swapping out the entire system for a smooth flow pipe that ducts in outside air. One day I will tackle that project...
  9. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    I don't think so as the Prius uses an Atkinson cycle engine which requires preheated air. That's why the Injen short ram intake is technically a hot air intake rather than CAI. You'd want to do a mod that sucks in more hot air.
  10. ecowhipz
    ecowhipz New Member
    Agreed. A warm air intake will theoretically improve efficiency, but a cai should still result in improved performance.
    I think it is safe to assume that there are owners who would give up some mpg for an increase in power. I personally would rather see an increase in both, but have not found a solution to that yet.
    BigPete, kknguyen1168 and Burna J like this.
  11. ecowhipz
    ecowhipz New Member
    So I looked at the stock set up and it seems as Toyota tried to grab some cold air after all. The snorkel extends to behind the headlight. If they were going for warm air it would have stopped sooner. Without something to test it is all speculation anyway.
  12. Bill Norton
    Bill Norton Senior Member
    2,108
    719
    MONW, Ks.
    This is not an INDUCTION UPGRADE.
    It is a style upgrade. And are you really spending that kind of money for colors under your hood?
    You guys are silly.
    You could have bought several cans of spray paint and had a RAINBOW of colors under your hood.
    If that's what you like,, fine....
    Those box chambers are there for acoustic dampening.
    4 cylinder engines can have an intake 'howl' at certain RPM's.
    If you want more noise from your car you could just cut off the muffler.
    ataylor2 likes this.
  13. toyotechwv
    toyotechwv Toyota Technician
    474
    251
    Princeton, WV
    Too late.:D
    SPH-D710 ? 2
  14. ETC(SS)
    6,841
    Wow!
    Unless the exchange rate between the GBP and the USD has changed significantly...that's a pretty expensive....er...."upgrade."
    I guess it won't hurt anything though....('cept the wallet!! :( )
  15. Burna J
    1,066
    3,335
    53
    Long Beach, CA.
  16. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I also ordered this.... and it came in yesterday (took a month from ordering and shipping from the UK)......
    I'll try to install mine tonight and post some pics.....
    Burna J likes this.
  17. Burna J
    1,066
    3,335
    53
    Long Beach, CA.
    It’ll be a very nice addition to your ride.. I'm sure you'll love it.
  18. ataylor2
    ataylor2 Member
    122
    East San Francisco Bay Area, CA
    You would see a bigger performance gain from taking a good laxative than you ever will from this thing.
    sarir97 likes this.
  19. xliderider
    xliderider Senior Member
    8,016
    3,198
    Honolulu, HI
    Are we talking jet propulsion now? :D
    SCH-I535 now Free
  20. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    Thanks
    I'm not after any performance gain....... Just want the look.....
