Accu-gauge tire pressure gauge
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jdcollins5, Aug 12, 2013.
  1. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I have the Accu-Gauge tire pressure gauge with the 0-60 psi dial face and the pressure release button. I have had this for a couple of years now and really like the 60 psi accuracy and the pressure release feature.
    I have found out (by unintended accident) that if you leave the pressure on the gauge, without relieving the pressure before storing, that this will cause a shift in the 0 psi position. I have gotten careless and done this a couple of times and the 0 psi return point had shifted about 3-4 psi.
    My wife's tires began to look under-inflated so I started checking the pressure with other pressure gauges and found out that the Accu-Gauge was off by about 10 psi. I have since bought another Accu-Gauge and raised the pressures back up to where they should be.
    I will try to be much more careful and be sure to always relieve the gauge pressure before storing in my tool chest :mad:
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I have a 30 year old Accu-Gauge that's still working great and spot-on accurate. No pressure retention though so its always at zero.
    jdcollins5 likes this.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,507
    1,613
    Bay Area
    This is what I use, never failed on me.
  4. El Dobro
    El Dobro A Member
    7,074
    3,258
    Stay away from these. They can be fairly inaccurate.
    ou812 likes this.
  5. bisco
    51,035
    ^^^that's what i use, how far off can they be? how do you verify gauge accuracy?
  6. El Dobro
    El Dobro A Member
    7,074
    3,258
    The pencil pressures were all over the place, even though the gauge popped out to the same pressure. I checked it with a couple of Accu-Gauges, which agreed with each other.
  7. NutzAboutBolts
    1,507
    1,613
    Bay Area
    lol, I assume you have 3+ accu-gauges? haha
  8. El Dobro
    El Dobro A Member
    7,074
    3,258
    When the pencil gauge had a 15lb variance that was shown by two Accu-gauges, that was good enough.
  9. joybird
    joybird New Member
    I have an old pencil gauge that I used for years on my '91 Honda CRX-HF, but I never thought to check if it was calibrated correctly or not. Ooops. Live and learn. :oops:
    However, having just traded up to a 2010 Prius, I suspect it's about time for me to spring for a better tire gauge! :D
    Anyone have an opinion about the Accu-Gages that have the rubber hose (e.g. model H60XA) vs the more compact ones (e.g. model 60XGA)? (Also, they seem awfully cheap on Amazon compared to what I expected. Or am I looking at models that are no good?)
    Also, on one of the other threads, someone mentioned it was important to get a gauge with a rubber boot around the dial. How come? Are the dials easily knocked out of calibration or something? Or is it just to protect the glass?
    Thanks for your help!
  10. jdcollins5
    5,131
    1,342
    Wilmington, NC
    I have the H60XA with the rubber hose. It is a good gauge. Just be sure to release the pressure before storing.
    The rubber boot is for protection from dropping which will impact calibration.
  11. MikeDee
    MikeDee Senior Member
    1,571
    596
    San Francisco Bay Area
    Actually, Consumer Reports found the pencil gage to be the most accurate.
    mtbiker53 likes this.
  12. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Reference, please...
  13. Mendel Leisk
    40,490
    I mainly use an old pencil gauge. Checked it a few years back with a digital and it was in agreement. It gives very consistent results too, ie: if you measure the same tire twice you will get the same reading.
  14. Den49
    Den49 Member
    498
    269
    Maryland
    My son gave me the below Astro Pneumatic 3018 Tire Inflator-Gauge for Father's Day three years ago. It is the best and most accurate gauge I have ever used. Between cars, tractors, trailers, etc. I have a lot of tires to maintain. This tool along with my air compressor makes it easy and quick to adjust air pressure. Drop someone a hint that you want one for Christmas. You will be happy you did.
  15. El Dobro
    El Dobro A Member
    7,074
    3,258
    I gave up on CR's opinions a long time ago.
  16. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    i do use one of these...:s... guess wont be using it anymore
  17. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
  18. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I don't have one, but I like the Accugage 60XGA simply because it can be operated with one hand. I also have the Milton pencil gauge and the Milton S986 that I like and it is accurate.
  19. nedear88
    nedear88 My 1st Prius.
    245
    141
    San Bruno, California
    this is what I use since 2001 and still works flawlessly. It is expensive but worth every penny.
    Racing Tire Gauge With Bleeder Valve
    Air Tools
    Tools
    - Griot's Garage
  20. mediahound
    903
    155
    I dislike digital ones because the battery could die on you unexpectedly and then it would be useless when you go to use it.
