Has anyone switched from a 5 door Prius to a Prius v?
Discussion in 'Gen 3 Prius Main Forum' started by stephensprius, Aug 20, 2013.
  1. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I'm just starting to look at my next option for a car/crossover. I have a 12 Prius model two. I want something a little larger, more backseat room, more room upfront too. I am a larger person, almost 6 ft 300 lbs. I feel a bit cramped in the front seat of my car. Will the v feel different in the front seat? I don't want to jump and get a cross over. I won't be happy with the mileage. I wish the v came with awd and a bit more umph.
  2. Michael M. Maslowski
    29
    Halifax, Nova Scotia
    260 pounds, 6'2" here. I have tested the interior of both vehicles and my verdict is the v. Mind you, the lift back is definitely on the spacious side i.e., it had plenty of space to accommodate my frame behind the steering wheel. That being said, the v is another story - tons of space above you and around you.
    Make sure to test-drive both vehicles.
    Good luck!
