  1. PriusFromFrance
    PriusFromFrance New Member
    France
    Ewww, I didn't know that ! Sorry for the mistake !
    I am watching for Valenti Taillights.. It will hyperflash too ?
    What is the LED "Relay flasher" ?
    Thanks
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    The Valenti lights have built-in load resistors to prevent hyperflashing so they'll work right out of the box, circumventing the need to install an aftermarket LED relay flasher to correct the hyperflashing.
  3. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    You can buy a LED compatible flasher relay and replace the OEM one located under/behind your dashboard on the driver's side.
    FYI, it's a real PITA to reach it and take out the original and insert the new one.
    SCH-I535
  4. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :) Working on installing the JDM style lighted side mirrors, Tuesday evening and yesterday evening. All I have left is to tap the wiring. Will finish up this weekend. Inexpensive mod with BIG results.
  5. quickbike
    quickbike Member
    39
    26
    Sacramento, California
    Thanks for this comment, I was about to purchase separate resistors for each bulb, but now I think I'll just buy the relay (only $9 on ebay!). I'm fairly thin, and hope i can get under the dash, we'll see. I do like the hyper flash.
  6. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    You like it? The vast majority of us find it highly annoying.
  7. quickbike
    quickbike Member
    39
    26
    Well, that's the reason I like it, it seems to be very noticeable to other drivers and they seem to give way. Here's my wish though, I wish it sounded and blinked normally in the car, while still being hyperflashing on the exterior lights.
  8. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    There is a better mod than putting up with the annoying hyperflashing. Install a tap turn signal relay which allows you to tap the turn signal stalk once and give you a series of blinks (up to 6 I think). They're compatible with LED bulbs and a number of members have installed it. autowindow.com
    Plus IV and quickbike like this.
  9. quickbike
    quickbike Member
    39
    26
    You should not have shown this to me,,,, thanks!
    riceroni87 and uropip like this.
  10. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    Same Here. That's on my shopping list now. Lol
    LG-MS870 ? 4
    quickbike likes this.
  11. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    I have it installed and it's awesome. It also makes the hazard flash programmable.
  12. riceroni87
    riceroni87 Senior Member
    360
    598
    Oxnard, CA
    I like it too. But..... when I see them flashing like that, my first instinct is to figure out which bulb went out.
    Galaxy Note 2 ? 4
  13. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    How easy is the install? Any step-by-step guides?
  14. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Finding and getting to the relay is tough. A lot of working one-handed. I posted a pic a few pages back showing the location of it.
  15. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    Well, it may not even be compatible with the 2013 model Prius, at least according to Tapturn. Anyone can confirm otherwise?
  16. CdotK
    CdotK Member
    376
    46
    Where did you get the adapter?
  17. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Just because they haven't updated their website to include 2013 doesn't mean it's not compatible. The 2013 is the same as 2012 so yes, it's compatible.
  18. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    This was the reply that I got from Tapturn:
    "I think 2013 stops using a separate flasher and has it built into the dash console.
    In other words, your flasher is not replaceable. I think.
    If you spot an 8 pin removable flasher that looks like tapturn then... I'm wrong and YES tapturn would also be supported in 2013. Prius. Cheers -Scott"
    So the question is, does the 2013 have an 8-pin removable flasher?
  19. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Sounds like they don't even know, but it's fishy as the 2013 in theory shouldn't be any different.
    Can't you find out yourself as you have a 2013?
    EDIT: PeterJMC recently transplanted the tapturn flasher from a 2010 to his new 2013 so I call BS on Tapturn's reply.
  20. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    My led relay looks the same as Tapturn, also 8 pin.
    Works for my 2013.
