Neighbor Prius2 battery died->Tow truck came->Horrific sight!!
Discussion in 'Gen 3 Prius Main Forum' started by prinut, Aug 24, 2013.
  1. prinut
    prinut Pri Nut
    102
    SouthFlorida
    She thought she did turn off the car after getting home late...anxious to go to bed.
    The battery apparently died since she could not get the car started.
    The car was parked head first in the garage.
    She called the tow truck/flatbed.
    I guess he could not push the car out, the front wheels could not move.
    He proceeded to hook up the car, turn on the winch and pull the car onto the flatbed, while the front wheels were stationary, tires SCREECHING like crazy.
    Doesn't this damage the tranny and was there a better way to get the car on the flatbed?
    She says it's a company car, so to her, it does not matter.....hmmm, buying a pre-owned Prius....anyone?!
  2. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
  3. ForestBeekeeper
    ForestBeekeeper Active Member
    770
    303
    Maine
    Rubber tires skidding on pavement or concrete do not screech.
    What could have possibly made that noise?
  4. bisco
    51,561
    owl caught under the wheels?
    Newpriusdanni likes this.
  5. bisco
    51,561
    but seriously folks, all they had to do was open the hatch from the inside and jumpstart her.;)
    ralleia likes this.
  6. jnet
    jnet Member
    196
    32
    1) use mechanical key to open door
    2) pop open the hood
    3) refer to the manual and put a 12v across the proper terminals
    4) this should get you enough power to pop open the hatch
    5) replace the 12v battery
    No towing is needed
    TonyPSchaefer and JMD like this.
  7. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I think the key is the "company car" part.
    IF
    value.her.time > value.company.car
    THEN
    tow
  8. JMD
    3,779
    1,282
    I'm not an expert in tow drivers, but one would think this guy had some knowledge.
    ralleia likes this.
  9. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Yes probably, but non of it relates to cars.
    John (Britprius)
  10. Former Member 68813
    3,524
    983
    US
    When tow track is called, they do what they know, that is towing. It was the owner/driver who was dense here. My daughter managed to get my car towed once due to illegal parking. It still drives fine, but I'm sure they abused it too.
  11. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    That would actually assume that the TTD actually gave a crap!
  12. JMD
    3,779
    1,282
    Towing is sort of the car experience.
    The infamous Boot
    The infamous Boot Solution.
    The gov response to the solution.
    The solution to the response.
  13. TwoUnderPar
    TwoUnderPar Member
    78
    72
    My wife's 2007 Chrysler Pacifica was parked in our driveway a couple of weeks ago. Parked facing the garage. Shift selector broke and car was stuck in Park. The local dealer ordered a flatbed tilt-bed truck to pick it up. You guessed it, hooked onto the back and drug it backwards onto the truck bed. Tires "screeching". Fixed the next day.
    Granted, a Pacifica has a transmission and a Prius does not, but dragging a car backwards at a slow pace shouldn't be enough to cause damage..... other than about 10' of tire scrub marks on the driveway.
  14. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    My response to your reply :D.
  15. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :mad:Many professions and businesses exhibit the same ignorance and incompetence. The really sad part, you pay top dollar.
  16. prinut
    prinut Pri Nut
    102
    SouthFlorida
    Neglected to mention that the garage floor was tiled.
  17. bisco
    51,561
