Scan Gauge II
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cary1952, Aug 31, 2013.
  1. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Where do you plug it inside the Prius? How do you mount it? On the window or on the dash, and can you buy the mount or does it come with one? Thanks.
  2. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    It plugs in the OBD Port. I placed mine ontop of the steering column against the dash with velcro, so it can be removed later. Then I ticked the cable behind the column so it's hidden. I can post pics if you want. Really easy to do, and it's always in front of me, but not distracting. Glad you got the Autozone deal. I wasn't able to, as I'm in Canada. Wanted one for my wife's "C"
  3. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Thanks I would love pictures. PM'd you also.
    hybridbear likes this.
  4. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
  5. bisco
    50,824
    very nice!(y)
  6. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    It works great, and it's not perminent. You can take it out anytime, and there won't be a mark left. It's been installed like that for 2 years now, and no issues.
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    My SG is mounted to a Sticky Pad with 3M Blue Putty. That Sticky Pad partially sits on another pad that has melted to the dash. The cable runs through the gap by the steering column. I bought a second cable for diagnostic use in other cars. The unit is sold with one cable. You have to buy everything else separately.
    It seems to me the ideal location would be permanently mounted at the left of the instrument panel but I'm not going to cut a hole in my dash.
  8. priusincc
    priusincc Member
    332
    NV
    I mounted mine the same way. The only trick is to set the steering wheel telescoping feature before you mount the unit, so you won't run into problems later. Mine has no issues, even though it gets a lot of sun.
  9. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I bit the bullet and ordered one today from Autozone.com. On sale for $127 + tax. Free shipping. Thanks for everyone's input.
  10. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Installed my Scangauge today using the same setup as above. I've been playing with it for a couple of hours.
  11. heyjack70
    heyjack70 Junior Member
    25
    I just installed mine today too! Disabled reverse beep. Have the guage showing rpm, coolant/enging temp, throttle position, and battery voltage.
  12. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    So how can the scan gauge actually save me money?
  13. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    FYI. $50 off ScanguageII at Advancedautoparts.com. Coupon code DOW36. Today is last day that coupon code is valid.
  14. heyjack70
    25
    That's a tough one. I think the advantage of the scanguage is to have more data, which is interesting to me to know about how the car is running. Not a money saver. I think you can keep tabs on the 12V batter voltage; it may be that as the batter is dying you will be able to pick it up sooner and avoid any need to pay for tows or auto service. That could save you the cost of the device.
  15. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    There have been several good threads on here about using SGII parameters to increase mpg and fuel efficiency. Try the search function and try terms such as hypermiling, fuel efficiency.
  16. hybridbear
    hybridbear Member
    267
    69
    Minneapolis
    Can you please add some more pictures in addition to what Fluxuated posted? I'm not quite following where the cable runs once it goes down behind the steering wheel and how it comes out at the bottom. And how do you secure it? I have a few feet of extra cable and didn't see a good spot to secure it easily where it would be out of the way. For me it's important to be able to easily move the SGII back and forth between the Prius and our Fusion Hybrid, possibly multiple times a week depending on which car I'm driving. Thanks!
  17. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Hey again! There is a plate (with a 1/2 inch opening) above the OBD socket where you thread the cable through and then you can roll up and I just used 2 ties and tucked 3 or 4 loops of extra cable above the same plate . You thread from the OBD up, not from the steering wheel down. It really is self intuitive once you go to the car and look at it and took me about 3 minutes to figure it out. I would buy an extra cable if you want to have it in 2 cars. Pictures would not be helpful because cable is hidden, sorry. Once you have the cable you honestly will have no problem! Enjoy.
  18. mrbigh
    3,686
    699
    Long Island, NY
    I think you should have it installed for you !!!!
  19. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    Purchased Scan Gauge from Advance auto parts on Friday. Scheduled to arrive on Monday. $50 bucks off with DOW36 code, $109.99 delivered to my door. Great deal, thanks to all
    for advice. Will install next week.
  20. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    $50 off scanguageII at advanceautoparts.com. Today only 9/14//13. Use code DOW37.
