What did you do to your Prius today?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Benggolf, Sep 10, 2009.
  1. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    Hi PC!
    . Washed and cleaned off tons of bugs this morning. It is love bug season in the south. On my last drive to Thomasville, GA. my car got a 5 o'clock shadow of love bugs. Disabled backup and alarm beeps at dealer, ordered LED JDM Mirrors (I know I said I would not, but I miss them) ;), installed rocker trim, ordered door handle trim from MIT Acc., and now thinking about speaker upgrades, instead of full AMP & Sub installs. I will adjust Fog light alignment tomorrow morning. Oh, and I installed the ABEO DVR Mirror!
    -Zed
    Les_PL and CSMgms like this.
  2. Alan Bullard
    Alan Bullard New Member
    I drove from Fort Walton Beach, FL to St Louis Missouri, ate at Sweetie Pies, picked up a rescue French Bulldog and returned home. got 53.1 mpg with no extra special effort. Did take more than a day however.
  3. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Added my Hybrid Nation badges!
    Here's one of them... Sorry for all the dust particles... hadn't washed the Flyer yet lol
  4. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    1. Couple days ago I installed windows deflectors. Rainy season is coming - I hope they'll be very useful during fall and winter. Original Toyota deflectors in local dealershop costs ca.250 USD. Found Internet shop in Poland - similar items for 30USD only. Looks good, also the material used seems to be good quality and they fit my dark tint on the rear :)
    2. Mudguards front and rear - done by Toyota - 100USD both pairs.
    3. Daylight LEDs by Philips DLII:
    4. From time to time using Mantis Instant Shine - enjoying the view in sunny and cloudy days :)
    5. Oil change from Castrol Edge 5W30 to Toyota Genuine 0W20.
    Drive, drive, drive... just for fun.
    ImeanGreen and xliderider like this.
  5. Delta Flyer II
    547
    248
    69
    Added my Hybrid Nation Badge to the C, now both Prii have their badges…
    Also ran the iPod cable through the dash… Got tired of the cable coming down the dash and then into the glove box… so annoying… lol… My OCD kicked in…
    Also added Duffy for the other half for commuting company LMAO…
  6. Delta Flyer II
    547
    248
    69
    Anyone know how to deactivate the function that does not allow you to key in infer when vehicle is in motion? That is no annoying? My BMW would allow you to, but Toyota does not…
  7. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    No can do, that is not something you can easily select off.
    You would need to spoof the ECU into thinking the vehicle isn't moving very fast. Here's an override from a PriusChat member:
    http://priuschat.com/index.php?threads/98717/
    And if you want an expensive plug and play solution:
    Prestigious Society » Navigation and Video Enhancement Module » Prestigious Society
    SCH-I535
  8. Delta Flyer II
    547
    248
    69
    Thanks so much Xliderider..... (y)
  9. VALCAS
    VALCAS Junior Member
    28
    Just installed 17" lexus CT200H rims on 205/50/17 yokohama tires, trd lowering springs.
  10. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Blocked the front grill. It was 45 degrees today, so I thought I would give it a shot. Total Cost $1.58 + 1 hour time.
  11. CdotK
    CdotK Member
    376
    46
    LOL @ 45 degrees... it hasn't been above 35 here for weeks... its been like 20-25 most the time
  12. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    It hasn't been above 25 here for weeks. Today we had a HEAT WAVE of 45, so I decided to do it before it got cold again. I did an extremely professional job!
  13. CdotK
    CdotK Member
    376
    46
    oh i see :cool:
  14. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    see my photo.
  15. CdotK
    CdotK Member
    376
    46
    nice, can you explain what you did there... i see you said you got a 7mpg gain by doing this... i could use a 7mpg gain... im all the way down to like 48mpg where as the summer i was over 50mpg :(
  16. kmkremer
    kmkremer Member
    227
    30
    San Diego
    Where can I buy those fog/turn signal lights?
  17. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    The following is a short lesson on how to do the Gen 3 lower grill block. 1st step: Purchase 7-8 foot piece of 3/4 inch pipe foam with built in split. I purchased mine at Ace Hardware for $1.49 plus tax. You will need to make 4 pieces. The lower 2 pieces are approximately 2 1/2 feet long. The upper 2 pieces are each about 1 foot long. Step 2: Measure the lower 2 pieces for overall length needed and cut. Step 3: Insert 5 notches to line up with the verticals in the prius grill. Make notch about 3/4 of the way through the tubing. THE LOWER 2 PIECES ARE IDENTICAL. Step 4: Insert lower 2 tubes around the horizontal lattice of the grill. Do not insert BETWEEN the lattices. Notches should line up. When 1st tube is inserted, it will appear loose, but when 2nd one is inserted the fit will tighten snuggly. Step 5: For top 2 pieces, cut each tube 1/2-1 inch longer than necessary so part of it can tuck behind license frame. Only one notch is necessary. Step 6: Fit 2 upper tubes into place.
    StevoB, mrbigh, Nora and 1 other person like this.
  18. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Hell, I'm down to 30MPG after this weekend of -16 degrees.
  19. BZzap!
    BZzap! Senior Member
    1,607
    878
    I'll bet your heating bill took a big hit too! :(
  20. ImeanGreen
    ImeanGreen Prius v Five BP Brigade #236
    547
    73
    Somewhere out there
    Les_PL , I like the location and install of your DRL. Did you install it yourself?
