View of PIP from behind.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bikeboy999, Sep 8, 2013.
  1. bikeboy999
    bikeboy999 Junior Member
    43
    Ottawa, Ont.
    2015 Prius v wagon
    Before I went on my trip to Las Vegas I read about someone in Ca cheating the system by using a non-pip Pruis in HOV lanes. Someone mentioned that there was a diff in the looks that they were able to determine if pip or not. What diff is there, I did take a photo but I have not fuzzed out lic plate, but will not post with lic plate numbers. But will post if fold want to see.
    Brian
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    From behind you can tell it's a PiP because the 'bar' that goes across below the rear small window in the hatch is silver on all PiP. It is body colored on liftback models.
    Also, the taillights on PiP models are clear, on liftback models there is red for the 2 'stripes' going up and over. Also, it has a HSD badge with a chromed plug on one end.
    Prius liftback:
    Prius Plug-in:
    Besides all this for the rear, on the PiP the door handles are also silver instead of body colored. The front of the car has a silver bar on top of the air dam, instead of all black on the litback and again, on the sides, it has plug in hybrid badging instead of hybrid badging.
    cwerdna likes this.
  3. PeteSJCA
    PeteSJCA 2013 Prius Plug-In Base in Winter Gray
    73
    san jose
    2013 Prius Plug-in
    Hey Brian,
    Taillights are 100% clear plastic, no red inserts like the none plug in. Side badging says Plug-In Prius, not just Prius, and door handles are silver regardless of the exterior color... that's all i can think of at the moment.
  4. El Dobro
    El Dobro A Member
    7,074
    3,258
    Different wheels, headlight plastic has a blue tint and let's not forget the charging door.
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:I alway wondered why some people obscure their license plates online. What about all the time you spend driving, locally, where I would assume the potential for problems is greater? Is their a difference?
    Rebound likes this.
  6. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    Yes there is
  7. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    How?
  8. Jeffrey Jessup
    78
    29
    Reno, NV
    I first noticed the differences while watching Under the Dome. The last episode I saw, they actually plugged it in.
  9. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    On the road, there's no way to associate your plate number with an online identity. This is important to some people.
  10. Fluxuated
    Fluxuated Member
    133
    53
    Guelph, ON
    Exactly. Some folks want a bit of privacy online, that you can't get while driving in public.
    I would say, that's not the best color options to use for the example. You can't see the silver strip across the back, which you'd see a lot clearer on a darker vehicle.
  11. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
  12. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    In California you need special stickers to travel in the HOV lane, so I'm not sure what the issue is.
    Even if you have a plug in Prius, without the stickers, you cannot legally be in that lane.
    ewxlt66 likes this.
  13. bikeboy999
    43
    Ottawa, Ont.
    2015 Prius v wagon
    Here is photo, it has some sort of permission being stated on the rear quarter panel and rear bumper. Is this the HOV permission for PIPs? prius with hov permit scaled .png
  14. mediahound
    903
    155
    Yes, those are the old stickers, which are no longer active as far as I know.
    The history is that before there were plug in hybrids, California allowed regular hybrids (for a few years) to get stickers. New regular hybrids no longer qualify. Only plugin hybrids and EV's can get the stickers now.
    Here's more info. - Eligible Vehicles - Single Occupant Carpool Lane Use Stickers
    Also note, even a PIP or EV can not use the lane (with a sole driver) without the stickers installed.
  15. fuzzy1
    10,335
    That is a GenII, so it cannot be a PiP. And the yellow stickers are from the old expired program. I'm seeing more of them up here in WA as old and used cars migrate away from CA.
    Did you get an occupant count?
  16. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yep! 2005-2006 gen II
