Lowering springs question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mediahound, Sep 4, 2013.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I am just wondering, can anyone tell me which springs in the pic below are the rear Prius Plus Lowering Springs and which are the front?
  2. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    The wider ones are the fronts.
    The ones with the dead coils are the rears (the dead coils go on top).
  3. mediahound
    903
    155
    Thanks, by 'dead coils' do you mean the thin coiled part?
  4. burstaneurysm
    469
    144
    Chicago, IL
    Yeah, the five coils that are scrunched up. When the springs are installed, those coils will stack up and touch, so it's really only the three coils at the bottom that are doing anything.
    This is what it'll look like.
  5. mediahound
    903
    155
    Interesting. I wonder why it's like that?
  6. burstaneurysm
    469
    144
    Chicago, IL
    The dead coils basically operate as a spacer and maintain the correct height and progressive spring rate.
  7. mediahound
    903
    155
    Thanks again. I'm getting them put in along with the rear anti-sway bar on Friday!
  8. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    How much do they lower the car?
  9. mediahound
    903
    155
    I think 1.3 inches at the most.
  10. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    You won't be disappointed. Makes for a whole new car.
    mediahound likes this.
  11. mediahound
    903
    155
    Enjoying it quite a bit so far. Handles way better and looks very good too.
    sarir97 likes this.
  12. mccal
    mccal Junior Member
    42
    BayArea
    How is the ride with the lowering springs? I am in a process on purchasing at 2013 Prius Persona with Lowering Springs installed, I believe this OEM lowering springs dealer installed. Do I need to add stabilizer bars, strut bars and lower brace to notice a big difference?
  13. mediahound
    903
    155
    I would add the rear sway bar, it's sorta a no brainier, part of the Prius Plus kit, priced well and easy to install.
    xpcman likes this.
  14. sarir97
    sarir97 Member
    265
    74
    Scottsdale, Arizona
    I think you'll be fine with just the rear-sway bar as an additional add-on. All the rest are nice but the return on investment is incrementally less.
    xpcman and mediahound like this.
  15. mediahound
    903
    155
    Agreed.
  16. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    I installed H&R but put the DEAD COILS on the bottom not top! What's the deal, any difference?
  17. mediahound
    903
    155
    I was told that the dead coils help to mate with the chassis so should be on top, but not sure how much difference it makes.
  18. burstaneurysm
    469
    144
    Chicago, IL
    Generally speaking, the spring should be oriented so the writing on the coil is right side up. Most of the spring installs I've done/seen have the dead coils up top, but I have seen them the other way around.
    BigPete likes this.
