Knee injury
Discussion in 'Fred's House of Pancakes' started by daniel, Sep 11, 2013.
  1. daniel
    14,487
    1,519
    Spokane, WA
    I don't think I mentioned it previously, but while hiking this summer I fell and hurt my knee. I'm not sure exactly what happened, whether the leg got twisted or jammed or what, but it was pretty painful. After a while I was able to walk slowly back to the hiking lodge. The next day, on the advice of the owner, a mountain guide with decades of experience, I took a very short, slow walk. By the third or fourth day I was hiking almost normally. Each day it hurt in the morning, and it hurt when I stood up after sitting for too long. It also hurt if I moved it the wrong way. But after walking slowly for ten or fifteen minutes it seemed to loosen up and I was able to hike, including some nine-hour hikes on some pretty difficult terrain. I iced it the first couple of days, and wrapped it in a compression bandage for the first few days.
    As soon as I got home I saw the doctor, and on Monday I had an MRI. Yesterday the radiologist's office called and told me I have a torn cartilage. (No details yet.) I have an appointment with the orthopedist on Monday. I have only uneducated guesses about what he might say.
    Anybody here have orthroscopic surgery for a torn cartilage? How long did it take before you were able to engage in athletic activity such as cycling, hiking, or jogging?
    I have a snowshoeing trip planned for December, and I'd hate to miss it. I'd get surgery, if offered, if I'd be recovered soon enough to get back in shape in time for that trip. I'd tough it out and snowshoe with the knee as is if the doctor says I would not be making it worse. After all, I hiked on it for two weeks, and I'm riding the exercise bike, which does not seem to make it any worse.
  2. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Someone close to me had that very procedure done quite recently. I was impressed with how easily it all went, and with the tiny scars. I recall the day when skiing buddies would end up with ugly scars from mid-thigh to mid-shin from knee surgery, often on both legs. So, things have definitley improved in that department.
    Walking unaided was easy after only a couple of days, with a bit of lingering pain negotiating stairs and hills. After two months, she's pretty much back to normal. So, barring complications and assuming a normal recovery, I'd say you should be fine for your December snowshoeing trip. Good luck. :)
  3. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Hi Daniel,
    About 15 years ago, I tore my right ACL foolishly going too fast down an icy slope on bad skis (like speeding in a poorly-maintained Yugo.) Never broke any bones, but would greatly prefer that over snapping ligaments, as the next ACL injury would definitely be worse.
    Having said all that, I'm fine as basketball and tennis or other activities involving twisting is not what I do.
  4. ETC(SS)
    6,910
    I'm not a doctor, nor do I play one on TV but I'd close the loop on this before venturing out on snowshoes on a long trip. Knee surgery is pretty non-invasive these days and gone are the baseball-like scars and the months-long healing times.
    Summer hiking and knocking around the house playing with the cat is one thing, but there's an increased chance when you're doing the Nanook of the North thing that you'll re-injure the dodgy knee, or make the existing injury worse. I know I wouldn't want to go padding around in the snow with a busted hinge.
    IIRC you're looking at something like 6 weeks in a brace or cast and maybe another similar time on light duty.
    Pleanty of time to shop for shoes before December.
    However (comma!!!!) your Doc will probably loop you in on all of this, and he or she will give more accurate advise about recovery times.
    Good Luck!
  5. daniel
    14,487
    1,519
    Spokane, WA
    I'm actually not looking for medical advice. I'll get that from the orthopedist on Monday. What I am hoping for, is someone to say "My friend so-and-so had arthroscopic surgery and was able to resume riding the exercise bike two weeks later" or some such.
    Six weeks on a brace and another six on light duty would put me into the middle of December and I'd miss the snowshoeing trip. I just want to hear (real) stories of quick recovery.
    I actually think I could probably snowshoe on the knee as it is. I hiked on it for two weeks after the injury, and snowshoeing is easier on the knees than hiking, since snow lacks the sort of obstacles that hiking has, at least the sort of off-trail hiking I was doing. For example, at the place I hike, 3,500 feet of elevation gain is considered a lot, whereas in winter they ski 5,500 vertical feet in a day. This is ski touring, where you climb up using skins. No ski lifts.
    But I'll take the doctor's advice if he says no.
    Note: I misspelled arthroscopic above. That was not a typo. I do make a lot of typos, but that was just that I didn't know how to spell it until I looked it up just now.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Sorry to hear about the injury D. I will say a prayer of healing for you.
  7. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    My experience in the hospital as a "non-doctor" is that most people are usually able to resume their normal activities within about 6-8 weeks or so. Cartilage isn't very vascular so it takes longer to heal then other tissues.
    The one deciding factor in my experience that has an effect on recovery time is how well the patient works when they go to the rehab stage. From your posts you seem to lead a pretty active life so that would lead me to believe that you would handle any physical therapy quite well. Others that are more sedentary don't "cooperate" with physical therapy as well so their recovery times can be longer.
  8. daniel
    14,487
    1,519
    Spokane, WA
    UDATE:
    I saw the orthopedist yesterday. He listened to my description of my fall and the progression of symptoms over time, then he examined my knee, then he looked at the MRI.
    The cartilage tear is so minor it probably has nothing to do with the pain. He thinks there is only one chance in a hundred it will get any worse. The real issue was/is a bruise on the bone and some inflammation of the tendons. Bone bruises heal by themselves, but very slowly, maybe another month or two. There is no treatment or therapy needed, other than to avoid impact (no jogging until it's completely healed) and continue exercising. I can take NSAIDs if I have a flare-up or if I'm planning an unusually long or hard workout.
    So I will keep riding the exercise bike, but will resume my normal number of days per week, which I had cut back on a bit just in case, and I will continue my long walks whenever the weather permits. I should be good to go by the time of my snowshoeing trip, with the proviso that I need to try out the snowshoes before making the trip, since walking in them is different than normal walking or hiking. (But modern snowshoes are much easier than the old-fashioned ones.)
    It is a big relief that I do not need to get surgery, and that I can continue to exercise without fear of making the tear worse.
    Several years ago, maybe 2007 or 2008, I hurt my ankle while hiking (I posted about it here at the time) and for the entire remainder of that season I had to stuff an extra wool sock down the side of my boot to cushion it. It always hurt starting out, and occasionally while hiking, but after ten or twenty minutes, it was mostly okay. I was able to hike the full season, and eventually (a few months later) it was healed. At the time I suspect that I had bruised the ankle bone, but didn't really know if that is possible. Now I know it is possible, and I am convinced that was the problem. Again back in January of this year in Sedona, I hurt my ankle while hiking and had to switch from boots to trail runners. By the time of my next hiking trip, in April, the ankle was fine. I think I may have bruised the bone again at that time.
    So strictly speaking the visit to the doctor, the MRI, and the visit to the orthopedist were not really necessary. But they were worth it for the peace of mind.
  9. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    No surgery is good news.
    Interesting anecdote about bone bruising, too. I think that's what's wrong with my ankle at the moment. Soccer's been on hold for weeks.
  10. daniel
    14,487
    1,519
    Spokane, WA
    Do you know the definition of "minor surgery"?
    Scroll down for the answer...
    Before we get to the answer...
    We played soccer in my high school. I took up my position near the muddy corner of the field, and the ball never came my way, and everybody was happy.
    I love hiking, and I exercise for health & fitness, but I've never enjoyed sports and I've never been any good at them.
    Surgery they do to someone else.
  11. BreakingPrius
    BreakingPrius Junior Member
    35
    I tore my ACL after years of running and being careless. I chose not to get surgery but I can't run anymore. After about a year, I'm fine as long as I don't walk up hill too often.
    That being said, my grandmother had the same problem at my age and did have surgery, which lead to a life time of problems and near disability from one infection after another.
    Read this too
    MRI Identifies Five Causes Of Complications From ACL Reconstructive Surgery
  12. massparanoia
    697
    467
    Virginia
    Glad you don't need any invasive surgery. Sounds like you should be good to go once the bone heals.
    From my past experience ibuprofen works better for this type of pain, at least for me anyway.
  13. daniel
    14,487
    1,519
    Spokane, WA
    Being unable to walk uphill would be so serious for me that I'd do just about anything to correct it. I'd certainly take the small risk of surgical complications. If I could not walk uphill I'd be unable to hike in the mountains. I'd be miserable.
    Presumably your grandmother was your present age 40 to 80 years ago. Medical technology has come a long way in 40 years. It was only about 40 years ago that fiber optics made the modern style of arthroscopic surgery possible.
    The study in your link began with 16 people who had had unsuccessful ACL surgery, and used MRI to find out what had gone wrong. This says nothing about the success/failure rates of this kind of surgery.
    I'm extremely happy that I didn't need surgery, but I'd have it done in a heartbeat if the alternative was that I'd be unable to hike in the mountains. -- And if they do totally blow it, there's always knee replacement. There are people running marathons on artificial knees.
    Aleve lasts longer than ibuprofen (12 hours as compared to 4, IIRC), which is useful for a whole-day activity. My orthopedist said that some people get better results from one, some from the other.
    I'm very lucky. It could have been a lot worse. It still could be. I don't take undue risks, but I've been on some extremely steep and sometimes very slippery terrain, some very scrambly ridges, some loose boulders. There are risks in everything we do, and I choose to take some controlled risks in order to be able to enjoy the most spectacularly beautiful country I've ever seen in my life, up close on foot, and to go off-trail (always with a competent guide) to get to the best spots my chosen wilderness lodges have to offer.
    Ruedi Beglinger (owner, with his wife, Nicoline, of my favorite of these places) says that the mountains are his church. A woman I see there every year says that she has to get into the mountains to recharge her spiritual batteries. (She always plans to be there in the dark of the moon, and she brings a sleeping bag and sleeps under the stars.) I don't generally use that sort of language, but I think they are expressing essentially what I feel: an emotional impact of being in those mountains which is calming and refreshing and emotionally curative, as well as awe-inspiring. Nature at its most impressive.
    I think that if I was religious I'd be an animist: seeing the divine not in a spirit in the sky, but rather in the rocks and the rivers, the trees and the flowers.
    As soon as the summer hiking season is over, I'm anxiously waiting for the next hiking season to arrive.
    I'm really glad I don't need surgery for my knee. -- The eyes are another matter: I will need cataract surgery next year if not this.
  14. massparanoia
    697
    467
    Virginia
    For some the naproxen works better, for others the ibuprofen does.
    I love being outdoors as well. I was an OTR trucker for a while and enjoyed seeing the country and being on the open road. I have begun to dabble in hiking, although it has been mostly local self guided trails so far. But I have gotten to see some pretty nice areas of virginia doing so.
