Poll: Are you Satisfied with the Prius Seats ?
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Jul 2, 2013.
  1. Fine, and I'm glad I was not forced to pay more for a power seat
    57.7%
  2. Good enough for my Use, although I am sore after a trip longer than 3 hours
    16.9%
  3. So so; I would have been happy to pay $500 more for power seats
    12.7%
  4. So so; I would have been happy to pay $1000 more for power seats
    1.4%
  5. The seat is a problem; I would have been happy to spend $500 more for power seats
    11.7%
  6. The seat is a problem; I would have been happy to spend $1000 more for power seats
    4.7%
Multiple votes are allowed.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Power seat is 8-way adjustable plus 2 way power lumbar adjust
    manual seat is only 6-way
    The other '2-ways' is the seat bottom cushion TILT adjust by tapping front portion of combo slide / height / tilt button on power seat. If need more thigh support, tilt up, less tilt down.
    If too much or little leg support, pressure, whatever on manual adjust seat, you're just about screwed and have to fish around for cushions, etc.
    If tall with too much leg support, pressure on thighs, nothing you can do. Sitting up higher on any added cushion is NOT what tall person would need. They would need front of seat cushion lowered, and that is virtually impossible with manual adjust seat.
  2. bwilson4web
    16,118
    I've done multiple 750 and 1,000 mile trips, 14-24 hour solo and dual drivers, in both our 2003 and 2010 Prius and only wish I could move both back about 0.25-0.50 inches. But my wife had two back surgeries and arthritis. I have gone to a salvage yard thinking about replacing at least her seat with one:
    • fully power articulating
    • rise enough she can lay down comfortably
    Since her most recent medical event, I'm now interested in:
    • seat that rotates and extends partially out the passenger side door (some tricky mechanical issues here and must be powered)
    • wider opening passenger side door with a mechanical lock so it won't swing when she uses it for support (possibly with a power assist on opening and closing)
    • rear passenger side door, suicide opening so we can more easily stow her wheel chair or walker (possibly with power assist on opening and closing)
    • removing the passenger side rear, hinged seat back or other passenger side, rear seat area, stowing option so there is more space behind the passenger side seat for various aids and a fully reclining passenger seat
    Actually, I would prefer an Estima minivan and think she would too. We loved our Caravan and would do it again if we could afford the gas.
    So yes, I would have bought an upgraded seat package for my wife. But due to age and medical issues, I am beyond what might ordinarily be offered.
    kgall and cycledrum like this.
  3. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    Like the pics of your mod but had a bit of trouble orienting myself. Am I correct that you installed a hinged, flip-out board about 5" wide and 12" long on the driver's side edge of the bottom of the center console? Nice idea! Did not think the plastic of the console would be strong enough to support the weight of your right leg like that. Does it bend at All? Do you then brake with your left leg or move the right leg off the board for braking? Board is unpadded, right? Thanks!
    First of all, very sorry your wife has the medical issues!
    Long time ago I was active in the field of human factors, also called ergonomics, and I saw examples of such rotating, sliding, tilting seats such as you describe. Unfortunately, I believe they were "one-off" feasibility studies or demos. Not sure where that research is right now, but maybe some of the NASA folks there could help point you at what is currently available?
    The space to work with is just very limited in the Prius, so small minivan probably is more practical from the overall height and room for custom installation point of view.
    If you do make a mod I would be very interested in pics and details. None of us are as spry as we used to be a few decades ago!
  4. iClaudius
    iClaudius Active Member
    435
    135
    Kansas
    One of the many reasons these online "polls" are labeled as bunk. They invariably confirm the views of the person writing the "poll". In this case the view of the "pollster" is "I tend to think a small minority...." which his "poll" then "confirms".
    Why Online Polls Are Bunk - Slate Magazine
    We do see a continuous posting of new threads as new owners discover the poorly designed seats that so many find uncomfortable. Some folks get overly defensive about "their Prius" and confabulations such as this poll which you, and others, "can't answer" are part of the defense of the dark arts.
    Is it the driver's seat or my butt? | PriusChat
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    The board is very thin 1/4" made of Poplar wood by 17" length, 3 1/2" wide.
    The lower console edge swoops from up to low and back up. The board spans the upward edges and is supported by them. The large clip merely holds the board in place and bears no weight. There is a 5/8" shim between the board and clip and it's attached with screws and lock nuts. There are pads on the board to resist scratches on console.
    Most of the board is covered in 1/2" neoprene foam. I still brake with right foot. I just happen to like feeling a console edge near my right calf. In a Civic, Corolla or Camry, I'd be resting my calf against the console.
  6. CdotK
    CdotK Member
    376
    46
    the way i look at it is that i didnt expect much from a 25K car... comfy seats, quite, smooth... its a 25K car.. a toyota at that... so going into it with these thoughts i was surprised and satisfied. If you want comfy seats and for it to have no road noise, and ride really nice you have to step up... get into the 35-40K range and you will get what you are looking for. Just saying.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    MPG's aside, very comfy seats can be had in the $25k to $28.7k sticker price range, 10-way power, perforated real leather at the 28k price .... that would be the new 2013 Honda Accord. Prius seat just doesn't compare to it, but yeah, Accord is a true midsize while Prius is something between compact and midsize.
    for those with complaints, will be much more effective to call, email or write into Toyota corporate (800) 331-4331. See toyota.com
  8. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    I don't care whether the seats are powered or not, but I have the "base" seats and they are very uncomfortable.
  9. maestrosteve
    maestrosteve Junior Member
    Toms River, NJ
    I agree 100%. Other cars have base seats that offer more comfort.
  10. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Your signature is sort of a crackup ... priuschat charter .... 'Prius is the best car in world in every way'
    I do not know man, I'd rather say Prius and good hybrids have the most potential to be the best cars in every way. It's got great tech, is clean and great on gas, but wow, to me it's just 'alright' as a whole. Needs major improvement in comfort, power, quietness, interior style, handling ... but we've heard it a buzzilion times before.
  11. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    The added comfort of the softex, power adjustment, lumbar and seat heater made the difference in comfort for me of buying a Prius vs. not buying a prius. Test driving cloth seats was one of the worst experiences I have had. Test driving a Persona with softex (but not adjustable) was quite a bit better. However, still does not compare with the fully power adjustable heated seats of a Prius 4 or 5 for comfort. Sometimes an 1/8" adjustment to my seat makes a HUGE difference, or a little more Lumbar support or a few minutes of Heat, when I have had a hard day and my back or hips are sore.
    cycledrum likes this.
  12. bwilson4web
    16,118
    So Thursday I visited the local Toyota dealer. I had gotten a 'teaser', a $20 off coupon for service. But while I was there, I took a peek at their Prius v. Compared to the C-MAX, much more space but the adjustable, rear seats gave me an idea.
    I can pull out the passenger side seat and the folding, passenger side, rear seat back. Then install rails to mount a new seat that has the ability to move all the way along the new track. In effect, the passenger side becomes a small 'lounge' for my wife with a seat designed to be fully articulating for my wife:
    • articulating seat and back
    • fully prone position
    • cushions and vibration isolation
    One new degree of freedom is to allow the seat to rotate 90-120 degrees towards the door. This will make it a lot easier for her to get in and out of the car. Once in the seat, it can rotate and shift back giving much easier ingress and egress.
    There are technical issues such as making sure the rails and seat are able to handle crash stresses without becoming loose objects. Also, the seat mounted, air bag needs to be addressed. Regardless, it sounds like an interesting and practical project.
    Robert Holt likes this.
  13. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Pictures!
  14. teamsc10190
    teamsc10190 Stereo Prii (2011 and 2006)
    145
    63
    Applaud the thought, however the poll as formulated doesn't sample opinions concerning seat comfort. Poll response choices offered are constructed around an underlying assumption that comfort comes as consequence of power seats and how much folks would be willing to pay for them. A power seat is a matter of convenience not comfort.
    Good orthopedic design is the foundation for seat comfort.
    If you were looking for a simple read on how folks perceive seat comfort, the question could have been something as simple as; "How would you evaluate the overall comfort of the seats in your Prius", using a scale of one to five with one being least comfortable and five being most comfortable.
  15. Robert Holt
    1,313
    889
    That sounds really interesting!
    (Ensuring "crashability" of that pivoting seat mount might be Problematic. In aviation test to failure is common method but too expensive / impractical in this case.)
    Would also like to see pics if you do this.
  16. Randy G.
    Randy G. Member
    113
    28
    Fullerton, CA
    Did I mention I have power seats?
  17. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Good orthopedic design is PART of the equation. Good ADJUSTABILITY is the other part and the manual seat has 60% of the adjustment capability of the power seat (10-way vs. 6-way)
    Sorry folks, but I get a little rattled by the notion that a power seat has nothing more than a fun button to play with.
    Even the all-new entry level Honda Accord LX with manual seat would be lousy to me compared to the next level up with 10-way power seat. Fixed tilt in a manual adjust seat bottom is merely a crap shoot for comfort for me. No lumbar adjust also sucks.
  18. teamsc10190
    145
    63
    I wouldn't disagree that the seat needs to be progressively adjustable to accommodate the widest range of body types. In well executed seats there are zero compromise in adjustability between manual or power seats. Toyota's cost driven execution of a manual seat is the culprit you're describing. Other manufacturers use rotary knobs in manual seats that are infinitely adjustable rather than the cheap detent adjustments that Toyota uses that limit the range of adjustment.
    That Toyota's manual seat offers compromised adjustability compared with the power variant is an indictment of Toyota's cost-driven execution that couples seat adjustability to your pocketbook.
    Manual seats with rotary knob adjustments are also superior in strength and crash performance than either manual seats with spring-loaded detent adjustments, OR power seats. For crash-test performance, a power seat is the worst-case scenario.
    At any rate; this thread concerns a simple poll for seat comfort. There are already plenty of threads about seat design.
  19. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I've seen rotary knobs for backrest in some VWs, but seems most top selling cars have levers for manual adjust.
    FWIW, here's a 2006 Corolla driver's seat frame and 2006 Prius frame:
  20. teamsc10190
    145
    63
    European cars have typically used rotary knobs. In manual variants, the rotary knob is turned manually. In the power variants, the knob is replaced by an electric motor. The seat frame is identical.
