My new grill block
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Sabby, Sep 18, 2013.
  1. Sabby
    Sabby Active Member
    295
    127
    SoCal
    I thought I would try a change from my usual pipe insulation grill block this year.
    One more from the front View attachment 57666
  2. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    Wouldn't it have been easier to simply put a piece of paper in front of your license plate?
  3. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    What is this for?
  4. Former Member 68813
    3,524
    983
    US
    Folks, it's still hot out there!
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Boy the east coast is really upside down. :)
    xliderider likes this.
  6. 2clicker
    2clicker Member
    114
    28
    St. Louis
    why even cover the plate at all? hundreds of people see your plate number every day/week and give two shits about it.
    whats different online?
    Rainking and mtbiker53 like this.
  7. Sabby
    Sabby Active Member
    295
    127
    SoCal
    By mid October it is cold enough here that blocking the airflow from the lower grill speeds up the warmup cycle and reduces the internal combustion engine firing up to provide cabin heat. In the past I have used the typical pipe insulation but thought this would be easier to install and might provide a little aero benefit.
    It will be put in place in a few weeks and will stay on until April.
    Sorry about the photos. For some reason my ipad picture posts end up flipped even though they are correct on the ipad.
    I was able to tuck this shelf liner material behind the license plate holder and under the front lip of the spoiler.
    Two little Velcro strips below and the elastic up front holds it in place.
  8. Skunkworks
    Skunkworks Member
    101
    Coming from a racing background and doing a lot of R&D on grill blocks I'm going to tell you that you are wasting your time with this, unless you built a more aerodynamic nose cone out of a rigid material.
  9. Sabby
    Sabby Active Member
    295
    127
    SoCal
    Seems like NASCAR testing on cars points out a different view of what works:
    "Depending on the type of track being raced on, different front end valences are used by the teams. All have grille openings to allow air to flow into the radiator and cool the engine. These appear rather similar to cars on the road. For short tracks and road courses, you'll see additional intakes for the brake ducts. These help keep the enormous drilled disc brakes cool, improving their performance (heat causes brake "fade," reducing effectiveness and forcing the driver to run slower to compensate). For speedways and super-speedways, tracks where speeds are consistently high and brakes are used more to trim speed going into turns, the vents and ductwork are removed. Speed is the key - any opening on the front of the car creates drag, and drag is bad.
    Enter the household item: duct tape, a.k.a 200-mph tape. Tape is used as an aerodynamic tool in NASCAR, as well as a repair device. If you look at pictures of the cars, you'll see the grille openings on the front. Teams will cover these with tape to improve aerodynamics and increase speed. If you watch qualifying, you'll see the openings are completely covered. The cars will only make 2-3 laps around the track during a qualifying run. The engine runs more efficiently when it is warmed up. Closing off the airflow to the radiator allows the water temperature to rise quicker. Once the car completes its run, the engine is shut off to prevent overheating. Occasionally you'll see steam venting from the right side base of the windshield. This venting is acceptable for the short period a qualifying run takes. Completely covering the openings allows for maximum performance, aerodynamics, and speed during qualifying."
  10. Sabby
    Sabby Active Member
    295
    127
    SoCal
    A bit better shot and hopefully not upside down. It is 53 degrees out here today so I took it for a test run. All seems well image.jpg image.jpg image.jpg
    spiderman likes this.
  11. mediahound
    903
    155
    You don't need to also block the upper grill?
  12. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    On the Gen III the theory is you don't want to block upper air vents as that cools the inverter. You want the inverter to run as cool as possible.
    Sabby likes this.
  13. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Might need two more straps. One on each side of the license plate frame, going up to the upper grill, lower edge. There might be some flapping in the upper middle area at higher speeds.
    Or maybe loop a strap up around the license plate frame.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Ah better! Make more sense right side up. :)
  15. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    The 'hole' at the vent area seems creating a drag. As other said, get rid of this 'hole' will enhanced the aerodynamic effect.
  16. gliderman
    gliderman Active Member
    751
    225
    Someone should make a bra for the Prius with no cutouts for the vents. Or cutouts with velcro so you could tune the airflow.
    Braddles.au and Robert Holt like this.
  17. EGGS
    EGGS Member
    108
    NYC
    ding ding ding !!! winner winner chicken dinner .
    i want to block the grill but i think the foam looks ghetto
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Or better yet, motorized louvers. ;) There was some JDM place designing them... I don't know if they ever went to production or not.
  19. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    Motorised louvres are available from Mooncraft in Japan. The "AEROPRIUS YURASTYLE neo" is the fully-aero and tested package.
    According to the price list and my amateur translation, the "neo Louver" is ¥33,600 but you'll need the "Lower Mask" at ¥32,200 to fit it. To automate it to open and close at a coolant temperature of 70°c you'll need the neo Louver with servo motor at ¥47,670.
    The "Slant Nose" at ¥24,150 extends back to the radiator to block air so that the top grille and bottom grille cool separate parts and the airflow is optimised. (That price list has been there for a while, so I don't now how current it is.)
  20. ursle
    ursle Gas miser
    1,049
    192
    NH
    All in all the pipe insulation will last another year;)
