Oh boy. Dead MFD/Radio/Clock/Side Mirrors
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BadPirate, Feb 18, 2006.
  1. BadPirate
    BadPirate New Member
    2005 Prius Non-Nav
    I was using the CAN-View product (plugs into back of MFD, and CAN-BUS), and it has been working fine. However, it came unplugged (from the can-view box not from the MFD) while I was driving and when I went to plug it back in I may have put it in the wrong pins. The result was a black MFD, no radio response, and a dead clock. I've checked all the fuses and they look fine, I have even replaced the 7.5amp main console fuse, but the results are the same. The car is driveable, but dark in it's mid-section. Anybody have any thoughts as to what my problem could be? I'm pretty sure that if I take this to the dealer it's going to be all my problem ($$$) because there is no way I can hide the mod.
    Help?
    Kevin
  2. Rick Grahn
    Rick Grahn New Member
    285
    Illinois
    Is there an in-line fuse for the display...or is there a fuse in the back of the MFD. I can't remember (it has been awhile since I installed my XM radio and had the back of the MFD exposed).
    RJG
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    which fuse block did you check? the one by the drivers door or the one under the hood. It's the #16 fuse second down on the right row on the panel exposed when the drivers door is open left side of the dash behind a cover about 3 1/2" x 5". The fuse layout is on the inside of the cover and should say Panel and is a 7.5 amp fuse. If in doubt pull them out and check with an ohmmeter.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Did you send Norm a email? He may have ideas. Maybe I should reconsider the modification of the CAN-View to add the programing module so I am not plugging and unplugging things all the time. Let us know how this comes out.
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Why not just replace them? Are they expensive?
  6. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    fuses or fuse blocks? fuses aren't expensive, but fuse blocks... quite the opposite.
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Normal troubleshooting procedure is to check the fuse, if bad then replace it. Expense has nothing to do with it. Thanks for tip Frank, I havn't even looked for that fuse panel location.
  8. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I meant the fuses usually when I have had a question I swap the fuse because I often can not tell if it is good by looking. Makes me get a set of spares for later use.
  9. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    have you tried pressing "Info"
    i know that if you turn the screen off.. you have to press info to turn it back on again
  10. DaveG
    DaveG Member
    806
    Vancouver, BC
    That wouldn't cause the radio or the clock to be dead though.
    Hopefully just the fuse.
    Dave
  11. galaxee
    9,810
    471
    MD
    what frank said.
  12. BadPirate
    I'm going to try the fuse box by the drivers side, haven't even heard of that one before. I'm really hoping it's just a fuse. At this point I'm fairly certain it's none of the fuses under the hood because I've checked them all.
    Kevin
  13. BadPirate
    That worked! Whoopie! Working car...
    ::dance::
  14. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    You NaughtyPirate, you...
    Glad to hear you got the car working again. Going to have to save this one for troubleshooting in the future.
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Changing the fuse???!!!
  16. wilanddij
    wilanddij Junior Member
    Indio, CA
    OK, my 2009 with 124k miles on it just did what sounds like the same thing.(radio/clock/MFD/side mirrors not working). Instrument lights are OK. My first thought, "its gotta be a fuse". Looked at all of them - none blown. Looked a little farther and discovered that there is only 8.4V input to #24 fuse. Any body have an idea what feeds 12V to the #24?
    Also looks like a trip behind the MFD might be a next move.
    Will Johnson
