Exterior lock button (driver door) rarely works
Discussion in 'Gen 2 Prius Main Forum' started by david123456, Sep 14, 2013.
  1. david123456
    david123456 New Member
    On my 2007 Prius the exterior lock button on the driver door works maybe 1 time out of 10. After shutting all the doors I press it and usually nothing happens (when it works, it locks all the doors and makes the beep sound as expected).
    Has anyone else come up against this, and what was involved in fixing it? Thanks.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    One of two things is probably going on. Either the 12 volt battery is weak, or the key fob batteries are weak.
    You can check the voltage of the 12 volt with the MFD. You can also replace the battery in the keyfob. It takes a CR2032 battery which is available at places that sell batteries. It is a common battery.
    The button will only work if the sensor on the car is receiving the signal from the keyfob and if the 12 volt is strong. If the keyfob battery is weak, the sensor has a hard time picking up the signal from the keyfob (reduced range due to weak battery). Also, if the 12 volt is weak, the range is reduced again. If you stand close to the middle of the door, the button will work better. If you stand behind the door in front of the rear door, the button will not work as well.
    Check out the battery's and beware of your position when you are pushing the button. The position does make a difference.
    Best of luck to you.
    2004-9 Prius Keyfob Battery Change <---- Change Keyfob battery.
    Weird stuff happening? MPGs dropping? Test The Battery | PriusChat <--- Check 12 volt
  3. bisco
    51,843
    if it's only the drivers door, it might be the lock mechanism.
  4. CasperPrius
    CasperPrius Junior Member
    Wyoming
    My 09 was doing the same thing. It got to the point that I had to pull the fob out of my pocket to even unlock which irks me to no end! I replaced the fob battery and everything is back to normal.
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    How about a bad seal at the door button? It's a rubber part, subject to the elements. Small hole letting in moisture, dirt? The other buttons work so maybe just one bad button.
  6. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Make sure you do not have a iPhone in your pocket. The iPhone often cancels the FOB.
  7. dorunron
    3,318
    1,105
    Houston, TX
    Just about any cell phone will interfere with the keyfob. If you carry a phone, you need to keep the fob and phone a good distance apart. Also it helps if the fob is closest to the sensors on the car rather than the phone.
