don't use B mode in heavy traffic
Discussion in 'Gen 3 Prius Main Forum' started by LlF, Sep 26, 2013.
  1. bubbatech
    bubbatech Member
    153
    60
    Alabama
    Where I live, there are numerous hills that will charge the battery to 80%. I use B for those areas all the time. Never in normal traffic though. I don't want to throw that kinetic energy away. I would rather convert it to electricity and store it in the battery.
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    I don't think the OP is at fault for anything. The idiot behind him is the one at fault. Hell, under normal deceleration I've been at risk with someone riding my rear bumper. Then if you pulse your brake lights you're an arseloff. People are just driving around in H. I.A. mode all the time.
  3. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I'm surprised your Prius had no damage, the rear bumper cover is notoriously paper thin. Seems like if you just look at it wrong, it dents.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    How have you measured the amount of braking from the ICE, with a full battery, in D vs B modes? The only thing I have to go by is how it feels and how many RPM the engine is turning. I can look at the tach and the speedometer for RPM vs road speed but the amount of braking without measuring G forces is totally subjective. You may be right but as I recall it's about the same in either D or B providing the speed I am maintaining is about the same.
  5. ataylor2
    ataylor2 Member
    122
    East San Francisco Bay Area, CA
    I suggest you have your car checked by a shop before thinking it has no damage. Often times the real damage is underneath the bumper covers.
  6. fuzzy1
    10,392
    It isn't necessary to measure actual braking force or Gs to distinguish the difference. On an appropriate hill, switch back and forth between D and B and make note of the differences displayed by:
    * Butt dyno;
    * RPM;
    * Speedometer.
    If you are maintaining speed in D mode, while your foot is off the 'go' pedal, then the hill isn't steep enough. The hill should be steep enough that the car 'runs away', gaining speed from gravity alone.
    For some range of steepness and speed, the car will gradually gain speed in D mode, but lose speed in B mode. On even steeper hills (e.g. the 7% grade on US 95 at Lewiston ID), both modes gain speed, but B gains slower than D.
  7. Mendel Leisk
    41,243
    We've had our car closing in on 3 years; I can't think of one instance when I NEEDED B mode. Came close maybe: coming into Whistler from the east, but even then, it was all ok
  8. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    B is the nearest we have to shifting down and yes there would be times when it's foolish to shift down instead of braking.:)
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is B because some one at Toyota was too honest to call it L.
    Toyota is legally required to have a gear like B.
  10. tumbleweed
    4,067
    692
    Eastern Oregon
    Thanks for the reply, I'll check it a little closer next time I'm in the mountains.
  11. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    I use B occasionally because I just hate heavy brake use at speed. I know, it's inefficient. Consider it PEV practice. ;)
    There's also some proper use where we a steady descent. Not many and I like to avoid that because it means we went up a lot to get there.
    OP could be considered to be at fault, depending on state law. In Maine drivers are required to avoid accidents.
    If it's clear you have a tailgater you really shouldn't brake rapidly without a working taillight. The whole problem with tailgaters is that they don't have enough reaction time.
  12. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    Don't. Minimize your tendency to do dangerous things! It helps in other aspects of life as well.
  13. ataylor2
    ataylor2 Member
    122
    I wonder if this technique is why I see 100 to 1 Prii smashed in the front.
  14. Former Member 68813
    3,524
    983
    US
    Some people just over-think the whole Prius driving. Drive it like a regular car for the best results. This how it was designed, to emulate a normal car.
  15. fuzzy1
    10,392
    Considering that OP had to stop, with real brakes and brake lights, to avoid colliding with the car in front, my state would not hold him at fault for the collision behind.
    The Prius B mode does not slow the car so quickly that a driver at minimum legal following distance, and being adequately attentive to the traffic situation, should have a problem stopping in time to avoid a collision. I'm well aware that this 'minimum legal following distance' does not reflect the reality of congested urban traffic in many areas, but that doesn't change fault.
  16. Mendel Leisk
    41,243
    I don't quite understand, how Prius slowing by B-mode is going to get front end damage, lol.
    Likely the reasons for front end damage are:
    1. The spectacular front end crumple zone.
    2. Cabbies.
  17. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I agree.
    Why people want to be "Clever" and use it for other things is beyond me.
    You bought a Prius.
    You bought a highly engineered vehicle.
    Don't try to out think the HSD system.
    Put it in D to drive, P to Park and only use "B" as recommended in the owners manual. How hard is that?
    xliderider and ftl like this.
  18. ataylor2
    ataylor2 Member
    122
    By people thinking this is a viable way to stop the car.
  19. LlF
    LlF Junior Member
    42
    Canada QC
    Whenever I put it in B, especially when the car is at a speed, I can see a very apparent CHG meter increase. It doesn't look like a waste of energy to me... (?)
  20. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    All the energy you used to spin the engine is wasted, the energy you get in regeneration, you would have gotten at least as much by pressing the brake pedal. Above 24 MPH there is never a 'win' in B. It is a safety gear, not a fuel saving gear.
