What is this piece under passenger seat?
Discussion in 'Gen 3 Prius Main Forum' started by mediahound, Sep 29, 2013.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    It says "Frame No."
    Anyone know that it is?
  2. afob3
    afob3 Member
    124
    40
    TN
    I found that when exploring my new to me prius the other day. If yOu remove that cover it reveals the metal chasiss below. That particular spot has the vin engraved there. Good to know I guess if other vin labels have been tampered with.
    TheLos likes this.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    Pop it off to reveal the chassis serial number (V.I.N).
  4. TheLos
    TheLos Member
    113
    Corona, California
  5. mediahound
    903
    155
    Interesting. Thanks for the info.
  6. El Dobro
    El Dobro A Member
    7,073
    3,258
    I went to one of the plug-in day events today and I don't remember if it was a Nissan or a Honda, but it had the VIN# cover like that under the hood.
  7. Josh83
    Josh83 Junior Member
    Frankfort, KY
    Some countries (such as China) require that number to be on there. Interstingly, if the number is damaged in any way during the manufacturing process, these countries will not allow the vehicle to be imported. They must be stamped to a very specific depth, such that they can not be ground off. You have to grind completely through the metal to remove the numbers.
