insulating the exhaust heat recovery system
Discussion in 'Gen 3 Prius Accessories and Modifications' started by edwardob, Sep 30, 2013.
  1. edwardob
    edwardob Member
    227
    33
    ireland
    anyone trie pipe insulation on exhaust heat recovery system...looks like it be safe enough
    anyone have ideas
    could speed up heating up...
    could be done on white/pink? pipes in picture
  2. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    No have not done it, but I am also interested in what can be done to improve MPG in the first 5-minutes warm-up. The other option might be something like an engine block heater for this area. Of course, presumably before you do this you would block the grill and insulate under the hood. Seems to me Plug-In Prius could have engine block heater and cat converter heater built in function after the battery is charged.
  3. edwardob
    edwardob Member
    227
    33
    ireland
    well there is a hole on engine for heater
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    seems like a good idea...
  5. Oscar Ramirez
    Oscar Ramirez New Member
    good afternoon I got an exhaust heat recirculation system toyota Futaba I want to know if it works in a Prius 2014?
    Thank You
