No beep or lights flash when locking doors
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by keymusic, Oct 5, 2013.
  1. keymusic
    keymusic Active Member
    205
    111
    Southern California
    There's no beep or flashing parking lights when I lock my doors on my 2011 Prius 2 when using the remote or the door handle sensor. I still get the 2 beeps/light flashes when I unlock. The lock beep was working fine and then just stopped. The doors still lock fine with the remote or handle sensor, just no beep/flash. Any ideas?
  2. M3Walker
    M3Walker Junior Member
    Calgary
    +1, My 2010 has the same problem..
  3. WienerMobile
    WienerMobile Junior Member
    29
    Madison, WI
    +1, My 2010 just started displaying this symptom.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    I believe on the 2010 this is a Customizable Feature. Any chance that you had the dealer change one of these features and they mistakenly disabled this feature ?
  5. WienerMobile
    29
    Madison, WI
    No, the last time they changed the features was several years ago when I had them turn off the beeping when in reverse. Door lock actuators have been replaced but that was months ago. Why would symptom appear now? Thanks for the reply.
  6. Kenny94945
    Kenny94945 Active Member
    840
    417
    Sausalito
    2016 Prius v wagon
    Old thread.....yet my nine month old 2016v is having this same issue.
    Locking...locks but no longer indicates that it has locked with a single beep or head light flash.
    In-Locking...unlocks as normal/ usual with a double beep and head light flash.
    I use the smart electronic "pass" key only.
    Approaching the car and grab the door handle to unlock.
    Place finger tip on the door handle sensor to lock.
    Search shows many have had this issue, yet there is no solution posted.
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Thanks. I will add this to my growing list of 2016 Prius "glitches" and keep an eye out for it.
    I went into the settings, and I disabled the lights flashing part, but I still hear the beep when locking or unlocking.
    Did you see that new thread someone started, about finding their Prius unlocked the next day? That has happened to me several times. I am positive I locked the car, I heard the locks slide forward and I heard the beep... But a few hours later, or the next morning, I go out to my car I find the drivers door unlocked!
  8. Kenny94945
    840
    417
    Sausalito
    2016 Prius v wagon
    Possibly resolved.
    Child lock on rear door was engaged.
    I found the passenger rear door child lock, black plastic switch on the rear inside sill of the door, switched to the lock/ engaged position
    Switched it to the open position.
    Car now beeps and flashes again when locking with the touch pad of the drivers front door handle.
    SirCharlz likes this.
  9. bisco
    51,033
    this doesn't sound right to me.
  10. drahgonfyre
    drahgonfyre New Member
    South San Francisco
    Hi - can you explain how you disabled the lights flashing? I want to enable mine. Thanks!
  11. Prodigyplace
    12,395
    11,676
    Central Virginia
    I remember that user being banned. This request belongs in the Gen 4 forum anyway.
    There is a Customizations section in the manual that shows what can be changed and where. They note what changes require a dealer. I am not able to paste a quote right now.
  12. Witness
    Witness Active Member
    115
    117
    San Francisco Bay Area
    Came across this thread because I just encountered this problem last night. It got me to check the child safety, which was I noticed one of the rear does didn't unlock. I hit the unlock button, but no luck. I figured maybe the actuator was faulty, but it was just in between lock/unlock. When I moved it back into a solid position, the beep came back. Hope this helps someone.
    Prodigyplace likes this.
  13. SirCharlz
    SirCharlz Junior Member
    2013 Prius Plug-in
    Thank you! This worked.
