Something you wish your Prius had
Discussion in 'Gen 3 Prius Main Forum' started by Delta Flyer II, Aug 23, 2013.
  1. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    A windshield washer low level indicator light.
    xpcman likes this.
  2. Jay Gloab
    Jay Gloab Junior Member
    27
    Cruise control that stays on all the time. I can't come up with any good reason why it should ever be off.
  3. markabele
    5,084
    1,782
    Nebraska
    Huh? Safety reasons. What if it's already on and you accidentally bump it to set at an inopportune time?
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Flux capacitor
  5. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    How about child window locks that don't also lock the driver out of the controls. Who thought of that??
    102mm likes this.
  6. e.e. comings and goings
    e.e. comings and goings Junior Member
    I wish the headlights would come on automatically, the way the ones in my ’99 Corolla did.
    Barring that, I wish there was a warning beep to let me know I’ve forgotten to turn them off. As, again, the ’99 Corolla had.
  7. e.e. comings and goings
    I wish there was a way to silence the back-up beeps, too. I hate backing into a space at night — I feel as though I’m waking everyone up.
  8. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    The beeps are inside the car, not outside.
    The default programming is to beep continuously while you are in reverse (Toyota's way of punishing their customers) but fortunately they can be easily reprogrammed by the dealer to just a single beep when you put the car in reverse. I find the single beep to be no nuisance at all and actually see it as a mild benefit.
  9. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    I sympathize. But, remember, the lights turn off automatically 30 seconds after the engine is turned off.
  10. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Something that would acoustically eliminate the whining coming from the right seat. My selective hearing doesn't seem to be as effective as it once was.
    Gorilla97 and xpcman like this.
  11. Rivetjoint
    Rivetjoint Junior Member
    New Jersey
    Some decent lighting for the cargo area.
  12. BruceN
    BruceN Junior Member
    Winter Springs FL
    Bottom of front bumper higher, so it isn't scraped every time it goes over those small concrete blocks when it goes over them.
    priusincc likes this.
  13. RaZa
    RaZa Member
    480
    93
    self driving
  14. RaZa
    RaZa Member
    480
    93
    Probably another "safety" feature which I can sort of understand. With the lock on nobody can open or close the windows, so no chance of an incident. If the driver had sole control there is a potential for an incident to happen. For example... Imagine a driver closing a window on your hand and you not being able to open it yourself. You yell and hope the driver understands enough to open the window back up quickly and not accidentally close it even more...
  15. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    What's CoG? Do you mean CoD, as in coefficient of drag? Or do you want a low gear for driving around at low speed in sand or snow? :D
  16. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Isn't that center of gravity? With the clearance of a vacuum cleaner, I don't know how much lower it could get :eek:
    xliderider likes this.
  17. xliderider
    8,033
    3,211
    Honolulu, HI
    Ah, that makes sense. They did wish for better suspension and handling. ;)
  18. southjerseycraig
    438
    107
    Cherry Hill, NJ
    be careful; I ripped the entire front bumper off trying to back out when the car was on one of those blocks. Always try to stop short of them.
  19. Josue Rodriguez
    Josue Rodriguez New Member
    I wished my pruis had turbo or supercharge... I still don't know if this is possible (if you have any information if this is possible or not please reply to this comment, I have a Pruis C 2012)
  20. Jay Gloab
    27
    The four previous cars I have owned that had cruise control, it stayed on all the time, unless you turned it off, even after turning the engine off. Never had a problem with it. If you need to slow down, you have to use the brakes anyway.
