pip battery/fan noise after shutting down
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bisco, Oct 19, 2013.
  1. bisco
    51,562
    i got home yesterday around 5 pm, and after 5 1/2 hours, noticed a buzzing noise from the battery area. it was 50 degrees out, so i don't think it needed cooling? anyway, i plugged it in for a minute and the sound changed, then unplugged and after a few minutes the sound shut off. never experienced this before, so long after shutting down. no sound this morning and charging now, no problem so far.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    It's normal... I usually relocate my PIP after it's morning recharge has completed from the public charge station around 10:15am, my usual lunch time is from 3-4pm. Many times when I go out to the PIP around 3pm (5+ hrs after last moving the PIP) or so I hear that fan (or something that sounds like some sort of motor) running. During it's run cycle I also hear it change pitch several times till it finally turns off for good.
    I think you could write a book covering all the strange sounds the PIP makes before and after starting or shutting it down :D
    bisco, Pbaker and giora like this.
  3. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    First - It is a relief to hear. Second - I wish other users would be as considerate as you are in using public charging stations!
  4. El Dobro
    El Dobro A Member
    7,079
    3,259
    Maybe the charger needs extra cooling, too.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    From T0yota's Manual.
    Approximately five hours after the hybrid system is turned off, you may hear
    sound coming from under the vehicle for several minutes. This is the sound
    of a fuel evaporation leakage check and, it does not indicate a malfunction.
    zhenya and bisco like this.
  6. El Dobro
    El Dobro A Member
    7,079
    3,259
    Like the PiP fart?
    Astolat and retired4999 like this.
  7. bisco
    51,562
    thanks everyone! what page is that on? i looked everywhere!
  8. retired4999
    2,652
    627
    Eau Claire, Wi.
    Gosh! I did not look at what page, took me awhile though. I'm beat from the long search!:sleep:
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    Owners Manual page 22.
  10. bisco
    51,562
    thanks man!(y) that is a lot of searching!
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    Anything for You!
    You Da Man! :whistle:
