2010-2011 prius Eibach sport lowering springs
Discussion in 'Private Sales' started by antech5, Oct 5, 2013.
  1. antech5
    antech5 Member
    160
    Sold, Sold Sold as of 12/23/2013
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    is this still available
  3. antech5
    antech5 Member
    160
    yes, still available, I don't often check my emails here. sorry for the late reply. I can get them shipped to Freemont, CA. for $15.00 by fed ex grounds.
  4. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Why won't these fit the 2013 pip ?
    iPhone ? - now Free
  5. antech5
    antech5 Member
    160
    my apologies, I checked the factory fitment guide. these will fit all 2010-2013 prius. so they will fit your 2013 pip.
  6. xliderider
    xliderider Senior Member
    8,054
    3,222
    Honolulu, HI
    Priusmpg, just be aware that the PiP is heavier than the non plug in, so your final ride height might be a bit lower than expected.
    SCH-I535
  7. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    How much heavier is a PIP?
  8. antech5
    antech5 Member
    160
    according to Toyota regular prius total weight is 3,042 lbs, pip weighs in at 3165 lbs, a whopping 123 lbs difference, so the weight will not affect the overall lowering height. all manufacturers will sell you the same springs for both regular and pip Priuses. so no matter what you decide to go with, it will not matter in the end.
  9. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I am willing to buy these if any DIY or instructions are available
  10. Sfcyclist
    1,621
    375
    SF, CA
    There's a DIY on this forum. IM me if you need help. The spring swap itself is easy, the most time consuming part is getting to the top of the front struts. Rears only take like 20 or 30mins.
  11. antech5
    antech5 Member
    160
    rears are super easy . front takes about 2 hours if done correctly.
  12. antech5
    antech5 Member
    160
    bump. I am surprised no one on the forum really wants to improve the handling and looks of their prius. This is a smoking deal
  13. axp2948
    axp2948 Junior Member
    24
    San Francisco, CA
    Do you have any pictures of the springs installed? I would like to see how much drop it gives the car.
  14. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Still available?
  15. still in school
    still in school Junior Member
    28
    how's the ride quality?
  16. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I had them on my last Prius. Ride quality was similar to stock perhaps slightly stiffer. Obviously the springs have to be stiffer themselves to lower the car and still keep it from being too low. But the ride quality also has to do with the struts/shocks used. I used stock ones with 10k miles and it was cool.
  17. still in school
    28
    I've tried searching for spring rates but couldn't find much. Do you know which are stiffer? These or the TRD's?
  18. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I don't have numbers but I remember doing the research and the TRD springs were stiffer (the white ones). I do know the Eibachs are progressive rate though.
