Are steelies okay on a Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mr_yellow, Oct 25, 2013.
  1. mr_yellow
    mr_yellow Junior Member
    66
    Technology
    Hi Guys,
    I recently just purchased a 2010 Prius and I want to get a set of snow tires for this winter. I'm a newb when it comes to prius stuff so hopefully this question doesn't sound too dumb...
    Is it okay to get regular ol' black steel rims? I don't care for aethetics but as long as the snow tires and rims are 5x100, 195/65R15's, are there any other things I need to take into account for the hybrid platform? Do most members here go with a different type of rim?
    Thanks!
  2. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    I can't think of a reason why not but since the 15" OEM alloys are pretty cheap used, why not just get a spare set? And you still retain the fuel efficiency.
  3. mr_yellow
    66
    Technology
    I actually thought of that but for some reason I can't find any except for an incomplete set in my area. :(. Anyone in toronto have a set they want to offload?
  4. Sfcyclist
    1,621
    376
    SF, CA
    Tons on ebay.. and if you are desperate, the gen 2's are 15" wheels as well.
  5. mr_yellow
    66
    Technology
    Doh.. not many options in the canadian market... =( maybe I'll put the winters on the stock tires and then get a set of 16" or 17" rims for summer time...
    What do those of you in the snow belt do? Are there some well known rims that work well on the Prius (preserves aerodynamics) or am I pretty much limited to the 17" OEM rims from toyota again?
    Thanks,
  6. Mendel Leisk
    41,165
    I'm using 15" Corolla steel rims with our snow tires in winter. I think they're in the vicinity of model year 2007~. I'll append this post with a part no tonight. Also got plain open-ended lug nuts. I believe there's a matching wheel cover, but I didn't bother. Didn't bother with TPMS either.
    FWIW, our OEM rims are 17", with 215/45R17
  7. mr_yellow
    66
    Technology
    Is there something special about the plain open-ended lug nuts? are the OEM lugs different somehow?
  8. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I ordered steel wheels with my winter tires from Tire Rack. They were about $52 each, and TireRack then mounts and balances the tires for free, so altogether it's a pretty big savings over sourcing your own alloys and paying to have them mounted.
    So, steelies are fine, but you do need to make sure they will fit your car - wheels differ not just in diameter and bolt circle, but in offset and hub diameter.
  9. Sfcyclist
    1,621
    376
    SF, CA
    The seat of the lug is what's crucial. There are 2 styles for Toyota's if I recall correctly, conical and flat. Steelies use conical. Alloys use flat. On the other end of the lug, it doesn't matter as long as it clear the stud. Conical ones are generally open or through hole and flat are closed.
  10. Mendel Leisk
    41,165
    The OEM lug nuts will work, only: they look a little odd. Normally they're recessed but on steel rims they stick out, and their washers are just loose. The plain nuts are low profile, utilitarian. Also just keeps them out of winter's worst.
  11. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I haven't had my stock lugnuts off yet, but I think Sfcyclist might be right - typically OEM wheels use a different seat - often a ball - than aftermarket. My steel wheels came with conical seat nuts.
  12. Mendel Leisk
    41,165
    The OEM lug nuts will fit: they have both a washer (effective part for regular alloy rims) and a the proper tapered seat (used if the temporary spare is swapped in). But they look odd in the latter application sticking out, loose washers.
    Here's my notes on the Corolla rims and plain nuts:
    Corolla steel rim, part no: 42611-02471-SW* (2007 model year?)
    steel rim lug nuts: 90942-01007
    Note: the rim is likely for 2006+ Toyota Corolla, and the corresponding wheel cover:
    42621-AB110
    * "SW" maybe stands for Steel Wheel, and not part of the part no? (this is as it appeared the bill)
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    They had to make the lugs fit both types of rims since the spare is a steel wheel.
  14. Sfcyclist
    1,621
    376
    SF, CA
    I just swapped my Tacoma ones out and should have took a photo. I can see what you guys are saying that the base is conical on the factory lugs. I have alloys wheel lug so what about the at washer at the base?
  15. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    They rattle around all winter driving me nuts... it was a short drive. :)
  16. Sfcyclist
    1,621
    376
    SF, CA
    Another reason to go with alloys! What another few hundred?
  17. Sfcyclist
    1,621
    376
    SF, CA
    So the steelies uses the conical or tip part of the lug. The alloys sit on the flats of the washer.
  18. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yup.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    They don't look terrible. I do like the fact that they keep the threads clean as opposed to the nuts that do not.
  20. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Another point that might have already been made is the steels are not hub-centric (at least the corolla wheels I have) but are lug centric. I have heard that this may not be good for the bearings.
