Change Lic. Plate Lamp
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JGC61, Oct 29, 2013.
  1. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    How do you change the lic. plate bulb on a 2010 lift back?
    Thanks,
    John
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved from technical to maintenance.
  3. alekska
    alekska Active Member
    435
    138
    Atl
    Open the hatch. Look at the plastic that covers the inside back of the hatch. There are 2 rectangular plastic doors in the middle left and right. Use a knife and pry the top part of the door. Remove the door. You will see the lamp socket. Turn the socket counterclockwise about 1/8 of a turn to release. Pull the socket+bulb out. Replace the bulb. Assemble in reverse order.
    - Alex
    xpcman likes this.
  4. world5
    world5 Junior Member
    Hi John,just checked,lift the trunk lid,in panel below rear window are 2 square covers,screw driver slots in top of covers,lever out from top to remove cover.Light fitting is removable by turning light fitting to the left,and remove to replace.:)
    Bob form NZ
  5. JGC61
    JGC61 Active Member
    216
    104
    Long Island
    Thanks for the help.
