Any way to run the seat heaters and rear defrost when plugged in?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by zhenya, Oct 24, 2013.
  1. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I'm sure this has been discussed fully, but I'm not finding a definitive answer. As much as I wish Toyota had equipped the PIP with a remote electric heater, they didn't. Is there any way to at least get the seat heaters and rear defrost to stay on when plugged in?
  2. markabele
    5,084
    1,782
    Nebraska
    I don't know of any way.
  3. El Dobro
    El Dobro A Member
    7,079
    3,259
    I'd be surprised if you can do that. When I get to work, I'll usually leave the system on ready and listen to the radio before I go in and then plug the car in to charge. Well, the other day, I plugged the car in first and then listened to the radio. After about 18-20 minutes, the radio shut off and the message "Auto Power Off To Conserve Battery" came up. That tells me the system is running only on the 12V battery while the car is charging.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Heat comes on very fast, so there is no need to preheat.
  5. markabele
    5,084
    1,782
    Nebraska
    Ya, I was surprised at how hot and fast it is...especially on high.
  6. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Thanks guys.
    Yeah, we've owned a lot of vehicles with heated seats and these are ridiculously fast. I often walk my dog around the block just before I leave and figure it'd be nice if I could get a jump especially on the defrost while plugged in. Too bad.
  7. El Dobro
    El Dobro A Member
    7,079
    3,259
    The exhaust has the engine coolant circulating around, so the defroster heats up fairly fast.
  8. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    No ICE use for me most days if I can help it. :)
  9. El Dobro
    El Dobro A Member
    7,079
    3,259
    With my commute, I go a bit past the EV range anyway, so some mornings I need the front defroster and it does heat up fairly quickly.
  10. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    You CAN run the A/C with it plugged in, which will help with defogging.
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yup, press the A/C button on your remote fob.
  12. El Dobro
    El Dobro A Member
    7,079
    3,259
    That will increase the charging time, correct?
  13. Ken Blake
    351
    180
    Portland, Oregon
    Yes, I hear it takes about 10 minutes extra.
  14. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Tried it this morning. Looks like the seat heaters do come on if the switch is in the right spot.
    A/C does nothing for frosted windows though! ;)
    lensovet likes this.
  15. Ken Blake
    351
    180
    Portland, Oregon
    I know, that's why I specified "defogging".
