Fog light housing removal?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dchill, Nov 1, 2013.
  1. Dchill
    Dchill New Member
    Austin TX
    Need to remove the plastic housing around the fog light. Advice on how to would be appreciated.
  2. xliderider
    xliderider Senior Member
    8,054
    3,222
    Honolulu, HI
    You have to remove 3 fasteners on the small corner undercover just below the foglight so you can access the back of the foglight shroud.
    It is held on by one screw and a couple of tabs. Removes toward the rear.
    SCH-I535
