check engine light stay on at 61000 miles ?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by us_matrix, Nov 1, 2013.
  1. us_matrix
    us_matrix Member
    110
    Got a 2010 Prius with about 61000 miles on it. Starting yesterday the check engine light stay on all the time (As soon as I started the car). I tried open and tighten the gas cap but no help and check engine light still stay on all the time. Any idea what could be the problem? Will any ODB scanner able to diagnose the check engine light code or need a specific one?
    Thanks.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    If it is a loose gas cap, it will take the car two or 3 days to turn out the light on it's own. I don't know about ODB scanners, but a Pep Boys will scan your car for codes and I think it's free.
  3. us_matrix
    us_matrix Member
    110
    I checked and the cap was tighten as it should be...
  4. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    You need to clear the code. It will not turn off if it is vapor emission related.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    You might get an autoshop to read the codes for you for free. Also the seal on the gas caps can wear out, but get the codes read first and report back...
  6. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    I disagree with both statements.
    Any OBD-II scanner should be able to read codes related to the check engine light. I recommend pulling the code and posting it here before doing anything else. Also, I recommend not clearing it just yet. If it is a problem covered by warranty you'll want to keep it there.
    Avi
  7. us_matrix
    us_matrix Member
    110
    Thanks guys. I am going to borrow a ODB II scanner from my friend and hope able to read the codes and report back to here.
