When heater is on engine won't turn off
Discussion in 'Gen 3 Prius Fuel Economy' started by ilovemymac, Nov 2, 2013.
  1. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    I have not had my prius in winter yet so running the heater is new. I am noticing the engine will turn off when warned up as in summer if the heater is off. You turn the heater on and boom engine kicks on.
    Which of course kills my milage and it's frustrating. Is it supposed to do this or is something wrong with my prius?
    Thanks
    iPhone 5 using Tapatalk
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yup, it is the only way to produce the heat for the cabin. You can turn down the heat and/or use ECO mode to help things out a bit. Cold temps and hybrids don't mix well but at 43mpg, it still beats most if not all the others out there.
  3. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    No, nothing wrong. The engine running makes the heat to warm you like in a regular car. It will cycle off when it can, but it still needs to run to meet heating demands you request via the HVAC controls.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  5. fuzzy1
    10,407
    During warmup, the ICE won't shut off until the coolant temperature reaches a certain threshold. That threshold depends on both throttle mode (ECO vs normal/PWR) and cabin heat (Off / On). That means there is a temperature band where, while sitting at a stop light, I can turn the engine on and off simply by playing with these switches. An engine monitor displaying coolant temperature will make more sense of this.
    Yes, it hurts MPG. Welcome to winter! And there are additional factors that hurt winter MPG.
  6. bwilson4web
    16,190
    Source: Relooking at warm-up | Page 6 | PriusChat
  7. El Dobro
    El Dobro A Member
    7,087
    3,266
    Since all cars have their fuel mileage affected by Winter weather, be happy that you're still getting better fuel mileage than they are because the Prius has a unique heating system. :D
  8. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    It does?
    So far I get poor milage as it is so I guess going from 45 to. 43 is not a big deal
  9. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    45 seems low under ideal conditions. How do you accelerate? What speeds are you driving? What's the pressure in your tires? How are you braking? Flooring it from a stop light and jamming on the brakes to stop would probably return that kind of MPG's. There's a slew of issues that may be present that no one here can answer without some feedback from you.
  10. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    Ohi have a whole thread on that and we didn't really figure out what the issue was.
  11. El Dobro
    El Dobro A Member
    7,087
    3,266
    The Prius uses the EGR cooling system and a water-jacketed exhaust to heat the coolant faster.
    You can see the extra pipes in this video.
    cwerdna and Jeffrey Jessup like this.
  12. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    1 is I have low profile directional tires 45 series I believe. I didn't put them on there that's what it had. I drive as much on battery as possible coasting when I can. I brake in advance easy. Ok not always I try but when there is lots of traffic it is hard.
    Weird thing is I typically see 45-47. 3 tanks ago I had 51 then back down since. Not sure what I did diff. But yea I did a whole thread and we never did figure out the issue.
    Someone mentioned checking the battery to see if it's not charging good. But not sure how.
  13. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Check the battery with a voltmeter. Check after the car has been sitting overnight or after a prolonged period of non-use. If the battery is the original, it could very well be weak or failing.
  14. El Dobro
    El Dobro A Member
    7,087
    3,266
    I read on a Volt cold weather tip sheet that using the seat heaters instead of the cabin heater to stay warm is more efficient. If you have the seat heaters, give that a shot and see what happens.
  15. ilovemymac
    ilovemymac Member
    170
    22
    Gardner, KS
    Yep use them lots. Love having leather seats so you can have seat heaters
  16. gliderman
    gliderman Active Member
    751
    225
    Seat heaters burn my butt and freeze everything else. I would rather have seat coolers.
    I dont know if its just me but my heater works ok when I take it off auto.
  17. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    This is either the first or second time I'd seen that video. I don't think I even knew it existed until now or recently... :eek: I was actually at that event where the filming took place, along w/Wayne Gerdes, the Priuschat moderators of the time + 40 or so other Prius fans, mostly Priuschatters.
  18. bwilson4web
    16,190
    Minor correction, the miniVCI data show the "EGR cooling system" is used at high power settings. During warm-up, it remains closed and this makes sense. The rich mixture during warm-up coming directly from the exhaust manifold would easily "coke up" the EGR heat exchanger.
    The miniVCI data also shows a binary signal, "Request Warm-up" that is associated with faster coolant warm-up:
    • 2.61 C/min - with "Request Warm-up" OFF
    • 9.62 C/min - with "Request Warm-up" ON
