Anyone know the Scan Gauge 2/ X Gauge O{2} sensor programming values
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by westy72658, Nov 7, 2013.
  1. westy72658
    westy72658 Jim Coleman Toyota in Bethesda, Maryland
    110
    67
    Louisa, KY
    My 2007 Prius threw a P0420 code and I want to check the operation of the two oxygen sensors to see if they are working. I have read in threads that there is a way to program your scan gauge 2 in the X gauge function to give these readings but I can't find the information to input. Can anyone post where to find these codes or a link to the ones I need? The two sensors I need are on both sides of the catalytic converter.
    I appreciate any help and thanks.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The only XGauges that I see in Adrian Black's SGII spreadsheet are the following:
    Catalyser temp 1 07E0013C 0441053C0000 2810 0001000AFFD8 Ct1 -40 – 6513°C
    Catalyser temp 2 07E0013E 0441053E0000 2810 0001000AFFD8 Ct2 -40 – 6513°C
    The O2 sensor is sensor 2. This is the temperature but not the O2 sensor signal that you are looking for. I do not see this in his spreadsheet.
    I hope this helps.
  3. westy72658
    110
    67
    Louisa, KY
    Thanks I will program those 2 !!
  4. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
