REBOOTING
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius1, Nov 11, 2013.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I have no theories, just a larger estimate number!
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Those are the only things that make a difference not taking out the battery :|
    Turn off signatures in Tapatalk Tapatalk
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    :) (y)
  4. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Like you said it's just a estimate number not the actual number of miles
  5. Andyprius1
    2,327
    859
    Cool CA
    Sorry I infringed on your post.
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Wat I never said that
  7. Andyprius1
    2,327
    859
    Cool CA
    What dat u say
  8. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    This thread has gotten hectic.
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    It's
    It's easy to make a mistake by posting inside a post.
    No harm done! :)
  10. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Will the pip charge if it doesn't have a 12v battery connected?
  11. Andyprius1
    2,327
    859
    Cool CA
    What is always very interesting about this post, and ( I have posted this on about three occasions) is: Everybody is quick to dispute, deride, criticize and rave of the futility of this idea. NOBODY is willing to try it. What a bunch of defeatist. This is how Tesla and Semmelweis were treated by fellow professionals. Incidentally, this is what you do, if you experierience a no start situation, so keep that in mind.
  12. Andyprius1
    2,327
    859
    Cool CA
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Alright Mr. Tesla jk, I'll give it a go tonight
  14. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    But you cant start it up right?
  15. Andyprius1
    2,327
    859
    Cool CA
    TY I anxiously await your results.
  16. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Me too
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    This is really stupid. No it doesn't improve your range. Essentially you are saying that by cracking open your older car's instrument cluster and manually shoving the fuel needle higher, you now have more fuel and can drive further.
    The estimated range is a constantly evolving number that takes no environmental variables into affect. It knows how far it went on EV, the approximate state of charge of the pack, and then extrapolates using your current driving style where will it be depleted to the point that HV mode is forced. That's it. Then this number is constantly averaged by every trip.
    If you take a brand new PiP off the delivery truck, then drove 5mph on a flat surface in the middle of the summer with 60PSI in your tires and a tail wind and achieved 30 miles of EV the estimated range would artificially high. Now park that car until the winter time, flatbed it to the bottom of a mountain, lower the tires to where the rims are barely above the pavement, and set off. The car will still happily tell you that you have 30miles of EV left. Good luck getting 5 miles. So then the average will read artificially low.
    By resetting the estimated range, all you are doing is taking a more accurate number that is constantly being honed in factoring in your driving conditions and style over time and throwing it all away. You gain nothing, and you lose the ability to more accurately calculate where that depletion range is.
    Saying you have to try it to believe it is like saying you have to try getting hit in the head with a frying pan to believe it hurts.
    Astolat, 3PriusMike and retired4999 like this.
  18. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    I know that but it can't hurt trying to prove someone wrong
  19. bisco
    51,855
    you can't start a prius without the 12v connected.
  20. vskid3
    vskid3 Active Member
    773
    228
    I say the burden of proof is on the one making the claim. I think disconnecting the battery does nothing to actually increase the range. You haven't even really claimed that it does, just that it makes the imaginary range estimate higher. Yet you want us to believe that the range increased?
