Not sure how but the top of my engine(mostly the battery/electric motor) is dirty. I have about 20,
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tgpii, Nov 9, 2013.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    Not sure how but the top of my engine(mostly the battery/electric motor) is dirty. I have about 20,000 mi on my Prius C. How can I clean that without messing the electronics etc in the engine?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    you should see mine! i even have pebbles sitting atop my engine. since i have under covers i can only guess it is coming through the grill.
    i want to wash but worried about water in the componets. i just brush it off. no problems to date.
  3. Mendel Leisk
    40,923
    Brush it off with an old paint brush? You can also use a shop vac on blow, to blow junk out of the corners. (or my favourite, a leaf blower ;)) One of those cat tail type duster wands is good too.
    I'd avoid spraying it with any sort of liquids, just my 2 cents.
    Assuming it's similar to a regular Prius, you can also pull off the ornamental engine cover, clean behind that.
  4. tgpii
    tgpii Member
    382
    63
    THANKS.
  5. frodoz737
    frodoz737 Top Wrench
    4,625
    2,483
    33
    Low pressure water from the garden hose will hurt nothing. I've done it twice a year since new. What do you think happens in there when it rains. Just don't go to the self serve car wash and blast every nook and cranny with high pressure and you will be fine.
    tgpii likes this.
  6. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    I usually wipe my engine bay and accessories clean every car wash or every other. That way there is never any major buildup / gunk that will have to be dealt with later on. Minor maintenance goes a long way.
    type17volkswagen likes this.
  7. B2FiNiTY
    979
    227
    Here's mine after 10K miles. Just wipe it down every once in awhile (every other car wash) and it will still be like new. Definitely helps when you sell the car private party down the road.
    I've had cars at 200k that look showroom clean in the engine bay. I've got california weather to thank for that too.
