Entune update 3.1.0
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mark_amdg, Nov 14, 2013.
  1. badboy99
    badboy99 Member
    119
    2003 Prius
    Running Entune 3.1.0 on Base model....Rocks...All of a sudden everything works like it should...less than 5 to install...get it...
  2. Zephyr7
    Zephyr7 Member
    301
    28
    biggest change is removal of auto play feature for bluetooth streaming audio and ipod/iphone.
    if you using an Android and want to plug it in, you are out of luck.
    I think the workaround is turn of MTP on your phone.
    Tracksyde and ftl like this.
  3. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    About time. There have been many complaints about this for the last two years.
  4. Zephyr7
    Zephyr7 Member
    301
    28
    it goes to show if you complain enough things will change.. just have to round these folks up to complain big time. lol
  5. davekro
    davekro Active Member
    511
    74
    SF Bay Area, East Bay
    2013 Prius Plug-in
    Zephyr7,
    Do you mean the obnoxious starting of playing whatever is default audio on your smartphone? (that is good!)
    What do you mean by this?
    What is MTP?
    Thanks I am new to connecting/using smartphones with the PIP system.
  6. davekro
    511
    74
    2013 Prius Plug-in
    Seems some have had problems with their dealers being aware of and being unable to download Entune 3.1 update. Anyone at Dublin Toyota (Nor. Calif) have the 3.1 upgrade done? Is an Entune update something dealers frown on folks dropping by to get? Meaning, it really needs to be at your next service interval? If anyone has dropped in just fro an update, how long was your wait?
  7. davekro
    511
    74
    2013 Prius Plug-in
    BB99,
    How did you get the 3.1? Did the dealer install at your normal service appointment? Trip to dealer just for the 3.1 update? Got (mailed or otherwise) a USB drive with the update and installed yourself? Basically, how can others get the update the easiest (and soonest :) ) ? Thanks
  8. badboy99
    badboy99 Member
    119
    2003 Prius
    Drove by a Toyota dealership, pulled into the service bay, talked to the service writer, told him I wanted 3.1.0.
    He said have it back in 5 minutes. I went and had free coffee and snacks, came back in 5, 3.1.0 was displayed on the screen, I thanked him and went to lunch...
  9. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    which dealer ship please?
  10. CharlesH
    2,797
    1,164
    Roseville, CA
    As I understand it, this thread is specifically concerning the Entune software in Base PiP. I recently got an Entune update over the air on my Advanced, but I have no idea what changed.
  11. vajratlr
    vajratlr Member
    197
    Los Angeles, California
    2013 Prius Plug-in
    is OTA update only available on the advanced model?
  12. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    that maybe just a app update i got a ota update on my base for the iheart radio app earlier
  13. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    That was the last OTA update I got for my C also, a few weeks ago.
    I believe all Toyotas with display audio, regardless of car model, run exactly the same Entune software, as I see the same issues on other forums when I do a search.
  14. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    On my list to have the dealer do at first service. Interested in hearing any other changes. 2.2 has actually been pretty good for me.
  15. davekro
    511
    74
    2013 Prius Plug-in
    Curious. What smartphone (and OS) do you use with 2.2 that has worked well for you?
  16. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    iPhone 5 and 5s on iOS 6 and 7. Everything I've tried has worked reliably - bluetooth streaming, calls, tethered streaming, iheartradio, pandora, etc.
    The only thing I haven't figured out is how to get it to display my actual text message on the screen. All it does is tell me I have a new message which isn't particularly useful.
  17. davekro
    511
    74
    2013 Prius Plug-in
    Z,
    Thanks for the info. I have an iPhone 4S on iOS 5.1.1. I have not gone to iOS 6 or 7 because of reading of some getting (greyed out) Wi-Fi broken. Probably a small subset of iPhone owners, but I have not had a need to go past iOS 5. Using Entune requires iOS 6 min. You and one or two others mentioned tethering. Curious, you already had tethering or you got it to use with the Prius? (I'd imagine the former) I looked into tethering as a way to avoid updating my iOS but on AT&T it cost like + $80.
  18. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Are you grandfathered into AT&T's unlimited data plan?
  19. Zephyr7
    Zephyr7 Member
    301
    28
  20. Zephyr7
    Zephyr7 Member
    301
    28
    OTA is always for Apps, core SW MUST visit dealer that is the RULE.
