those who have Entune 3.1.0, can you help us out??
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by vajratlr, Nov 25, 2013.
  1. vajratlr
    vajratlr Member
    197
    Los Angeles, California
    2013 Prius Plug-in
    You can download the firmware from your car onto your USB flash drive. It shouldn't take more than a couple minutes as I tried it with 2.2.0. The file size for 2.2.0 is 14.5mb so I can't imagine the newer release is that much bigger. After download, you'd have to either email or upload the file to a FTP site. Any volunteer? Thanks!
    I could be wrong, but I checked the 2.2.0 that I downloaded to my flash drive and I couldn't see anything that would suggest personal data being downloaded. Furthermore, there's an option that you can actually backup contacts and stuff which is not what I'm talking about here.
    here are the steps:
    setup>general>scroll down>system information>lower right corner you'll see "copy to USB"
    And I think it should be more than just 1.8mb. My 2.2.0 as mentioned was 14.5mb.
    [​IMG][/URL]
    markabele likes this.
  2. Priusmpg
    Priusmpg Active Member
    628
    108
    Fremont, California
    2014 Prius Plug-in
    that would be great, anyone?
  3. Ph33zy
    Ph33zy Junior Member
    26
    Irvine
    I could try tonight when I get home. I just had my 15K inspection and they updated my Entunes to 3.1.
  4. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Looking forward to it (y)
    Turn off signatures in Tapatalk Tapatalk
  5. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    How did you download the firmware to the USB drive?
  6. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Setup> general> scroll down > back up I think
    Or it gives you an option once you plugin the device
  7. Ph33zy
    26
    Irvine
    well i just downloaded it quickly to my usb drive, but the sum of the total file is only1.77mB after being zipped up. I'm not sure if this correct. I'm kind of afraid to upload it in case it contains just my own data files since the size is so small.
    Can anyone confirm this?
  8. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    We discussed that menu option on the head unit before and I think it was concluded that the data you get when you use that download option is your own data (phonebook, contact list, etc).
    Although 1.8MB seems rather large just for phonebook.
  9. Ph33zy
    26
    Irvine
    Well it says 488kB, but the file size on disk is 1.8mB.
  10. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    I'm not sure if we're talking about the same thing? see my edited original post...
    Priusmpg likes this.
  11. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    Did you go through the same steps as what I just said in my edit?
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I think the car needs to be at rest to see that System Information menu.
  13. Priusmpg
    628
    108
    Fremont, California
    2014 Prius Plug-in
    Yes it does
  14. mrbigh
    3,686
    699
    Long Island, NY
    I'm clinging to this thread for further improvements
  15. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    no one is willing to help out??
  16. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I cant find the post(s) here where it was discussed, but here's someone else's comment from another forum:
    "Old" Entune software - Toyota Nation Forum : Toyota Car and Truck Forums
  17. vajratlr
    vajratlr Member
    197
    2013 Prius Plug-in
    I screenshot the 2.2.0 folder that I downloaded, you can clearly see 2.2.0 in the bottom window. Not sure if that means Entune is also downloaded. Unless someone has actually tried installing, I'm not fully convinced this doesn't also download Entune. Just by looking at it doesn't tell you much.
    [​IMG][/URL]
  18. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I created the backup on my Prius c, which has 2.2.0 installed, and I got the same as shown in post #17. This is *not* a full Entune backup. The folder on my USB drive is also NaviSync, and the total size of its contents is 780KB.
    When I received the red USB backup stick from Toyota in June 2012 (the only update that has ever been distributed). I saved the content:
    The USB stick as received contained only the swdl.iso file. The swdLog.txt file was created during the update and contains the results of the installation process.
    See my post from last year with details of what's in the ISO file.
    Got my entune flash drive today!! | PriusChat
    Without the ISO file, you don't have the Entune software.
  19. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I still have 2.1.0 so I will even be happy with 2.2.0 as I get the dreaded can't navigate from your current location error on the occasion.
    iPad ? HD
  20. chesleyn
    596
    158
    Los Angeles
    Crickets.... :(
