Tire PSI
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CdotK, Nov 27, 2013.
  1. CdotK
    CdotK Member
    376
    46
    I searched and looked through many pages of threads and cant find a clear answer. A lot of bashing and opinions is all I find!
    Anyways, my question is: I am running the stock 15's with the wheel covers off... what PSI should I be at for max MPG?
    Also, should I put the wheel covers back on to increase my MPG?
    Thank you
  2. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    I am running 36 in my winter tyres 195/65/16. I usually run up to 40 in my 16" summers
    Doubt covers will make any measurable difference to mpg
  3. CdotK
    CdotK Member
    376
    46
    i remember reading something about running 40PSI but i couldnt find anything. I just took my car in for the 10K service and they put the tires at 35PSI and my MPG is down to like 47 on the display whereas its always been 50+... i had the PSI at 40 just couldnt remember 100%
  4. Bingee
    Bingee Member
    210
    62
    Michigan
    Winter snow tires 15s. 42 front 40 rear
    Summer. 15s. 46 front 44 rear
    Works good for me after a lot of different trying
    Danger likes this.
  5. Fore
    Fore Don't look back!
    494
    107
    Plenty of forum topics on this, but for my 15" tires I put in 36 psi front and 38 psi in the back. My over all mpg is usually 50+ but starting to go down due to colder weather and winter mix in the gas. It will probably stay in the upper 40's mpg's for about four to five months until spring time hits. No covers with mud flaps on my vehicle and window visors installed. It all boils down to how you drive it, if you want better mpg's. Hope that helps you!
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    A lot of members run their psi up to max sidewall pressure for best mpg. I personally run mine at 40F/38R. The higher psi is a little too stiff for me.
    I do not remember seeing any testing that shows an actual psi versus mpg graph.
    I have not noticed any mpg impact from removing wheel covers.
  7. CdotK
    CdotK Member
    376
    46
    thanks for all the input and no bashing!!
    Ill set back to 40PSI and see how it goes!
    Happy thanksgiving to everyone!
    Tony D likes this.
  8. vskid3
    vskid3 Active Member
    773
    228
    If you want the absolute highest mileage, you can't go wrong with the sidewall max (which is what I run). However, many people find the ride too harsh at that pressure. There is a comparison of different pressures coasting distances here. It looks like after 45PSI, there isn't much of a difference in rolling resistance.
  9. CdotK
    CdotK Member
    376
    46
    doesnt running that kind of PSI (+40PSI) wear the tires un-evenly?
  10. vskid3
    773
    228
    Mainly in older bias-ply tires. Radial tires have steel belts in them that keep them in shape better. There are many people who use the sidewall max or even higher and most see even wear over the life of the tire. Just keep an eye on your tires and rotate them every 5-10k miles.
  11. CdotK
    CdotK Member
    376
    46
    Interesting! I think i will go up to 42PSI and see what i get. Ill update next week with results.
    One other thing that is to my disadvantage is that its starting to get cold in the mornings (28-30 degrees) and from what i read they change the blend in the gas up here in UT
  12. vskid3
    773
    228
    Yep, winter isn't kind to gas mileage. I've been averaging about 60MPG up until this tank. Its been in the 30s in the morning and I'm only getting about 51MPG on the MFD.
  13. CdotK
    CdotK Member
    376
    46
    Ouch! that like a 10MPG hit!
  14. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    At max sidewall pressure on my 15" Intregrities I was still getting edge wear, a sign of underinflation.
  15. retired4999
    2,652
    625
    Eau Claire, Wi.
    Run 40 psi front and 38 psi rear, yes 2 pounds less in rear helps the car to track better more stable. I have done this for 8+ years in both of mine, 2005 and now 2012 and both have worn evenly across the tire, no problems at all! :)
    xpcman likes this.
  16. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    My 15's,
    44 in front, 42 rear, rotate every 2k miles.
    So far no noticeable tread change.
    My gain was 7
    Danger likes this.
  17. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Wow, that's extremely frequent. I rotated every 10k miles on the OE 215/45/17 Bridgestone Turanza EL400-02. Got 65k+ out of them and perfectly even wear across all four.
  18. Mendel Leisk
    40,461
    ^ Agree. The object of tire rotation is just to even out the tire set's wear, over it's lifetime. It's kind of like flipping a steak on a grill, theoretically even one flip would do.
  19. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    Edit, it's every 5k.
    New tablet :D still in learning mode (so is user).
  20. CdotK
    CdotK Member
    376
    46
    Here is an update as of 12/9/13
    I raised the PSI to 42 all around and i still am only getting 47MPG... We do have the winter fuel blend going on and its been WAY cold here the last week, only getting into the teens.
    I think i am going to lower the PSI back down for a softer ride since the MPG is down no matter what i do.
    Thanks for all the info and help!
