If 12v battery is dead, how do you get in the car?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CaliforniaPrius, Nov 29, 2013.
  1. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    There is no physical key for prius. Then how do you get inside for the jump start?
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  3. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    There is a valet key on the side of the fob you can slide out and unlock the door.
    Then use the jump start terminal inside the engine compartment fuse box to jump start, but be very careful to follow the instructions in the owners manual. You can cause a lot more expensive damage doing it incorrectly or using a source with too many amps. If it's the original 12-volt, probably just ought to replace it.
  4. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    The number of amps available has no bearing on the safety of jump starting the Prius. Connecting with reverse polarity is the number one enemy, and liable to cause maximum damage. It is also advisable not to have the downer jump engine running, this is because alternators can give out high voltage spikes, not good for the Prius electronics.
    John (Britprius)
