Is this a symptom of a dead batter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by yawkeyfan, Nov 29, 2013.
  1. yawkeyfan
    yawkeyfan Junior Member
    NH
    I have a 2004 Prius that has been relatively maintenance free. Oil changes and brakes. That's it!
    But recently, I've had to jump start my car 6 times in the last 6 weeks, three times in just last week.
    When I open door overhead lights dim and the car makes a beeping sound as if I've left lights on, but all lights, etc. are off. I shut door lights and beeps stop.
    When I put the key in and push start button, I hear one beep and the dash light illuminate as if it were going to start, but it won't start. The lights that indicate the fuel levels will only flash one box, even though the fuel tank is full.
    I've never replaced battery. Is there a way I can tell that its just battery and not an underlying electrical problem? I don't want to replace battery if there is a problem that will just keep draining it. Also, the touch screen panel died a couple of years ago. It keeps flashing on from time to time, but there seems to be a loose wire. I think its unrelated as that happened long before I started having problems with starting the car.
  2. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    If that's the original, you're luck it's lasted that long. If you have a multimeter you can check the 12-volt voltage on the battery. It should be 11-14 volts. I recommend replacing it before you damage something even more expensive with all the jumping. Prius is very sensitive to reversing polarity when jumping.
    One of the main things the 12-volt really does is run electrical systems, including ECUs and those lights you have said dim, so the Hybrid system can act weirdly or not run at all when 12-volt is bad.
  3. yawkeyfan
    NH
    Thanks for the quick reply. I appreciate it. I will test and pick one up..........
  4. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    You may see some posts that recommend after-market batteries, but also a lot of modifications needed for them. I recommend the OEM Prius battery. It has the correct size posts, vent tube attachment, fits in the space without modification of the tray, and has a carrying strap that fits under the harness. Others require modifications.
  5. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    As far as the touch screen flashing, did you ever replace the OEM radio or anything else that required full or partial disassembly of the dash?
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  7. yawkeyfan
    NH
    No, honestly. I've had nothing for repairs, other than standard maintenance. And, I have 277,800 miles on this car. When the screen went, I just did withou.
  8. bisco
    52,787
    you may have the record for longest surving 12v!
    hkgngplugin and yawkeyfan like this.
  9. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    That's very good lifespan. If you haven't read other posts, have you changed the transaxle ATF fluid at a couple points?
    Back to the Multi-display. Have you checked for any DTCs? B1248 can be a bad or loose wire harness from the Gateway ECU to the display?
  10. yawkeyfan
    NH
    I've never brought it to the dealer. I bought it as a certified preowned car in 2008; it had 40,000 miles on it. All maintenance has been done at either Valvoline or the Monroe Oil changes places...Whatever, they;ve recommended, I've done. I honestly don't know what they change. I did switched to high mileage oil. I am aware that I've been lucky but I've always owned Toyotas and have never gotten less than 250k miles from any of them......
  11. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    I'd say good maintenance is more important than luck in this case. The only reason I ask is because Toyota considers the Transaxle ATF "lifetime", but many members here recommend replacing it at about 60,000 mile intervals. I first did mine at about 120,000 miles and it was very dirty, but hadn't caused any damage. Very simple procedure though, just drain and fill, no flushing, so well worth the cost.
    yawkeyfan likes this.
  12. yawkeyfan
    NH
    Oh, and on the display, I think its just a loose wire. I went on YouTube and learned how to remove the unit so I will and check the wiring. It blinks on and off and I believe it just a loose wire. I want to do that before winter because last winter was tough to get the heat and defrost regulated easily as its more cumbersome toggling through the heat using the buttons on the steering wheel.
  13. yawkeyfan
    NH
    Great sounds simple enough. That will get done after I figure out the battery issue.
  14. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    Sounds good. Let us know if it works.
  15. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I think it's actually a bad solder joint and apparently it's a fairly common problem. If you search this site you should be able to find more details on this, and I think there are even some independent specialists who can fix it fairly cheaply if you send it to them.
  16. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    RE: MFD There is a pretty good post from Hobbit about the issue that you may be having and some solutions.
    Check link below. As uart said it can be a solder pin connection that has broken, usually either pins 58 & 60 or 59 & 60.
    Prius MFD
    RE: Transaxle ATF- You can remove the fill plug and draw out a small sample of the fluid to check condition. Recommend always using Toyota ATF WS as a replacement although if you have had Valvoline or Monroe actually replace it, since you have close to 278,000 relatively trouble-free miles, you have either been doing something right or very lucky.
  17. hkgngplugin
    hkgngplugin Junior Member
    46
    Hong Kong
    I can’t agree anymore than this. Get your 12V replaced and everything should go back normal!
  18. yawkeyfan
    NH
    Ok few lessons learned. The 2004 Prius is one of a few that has three batteries. I got the first one from the Auto Parts store $222 and it was the exact one mentioned in this forum Optima Ds462B24R. When I googled the part and went on three auto parts store website, they all came up with this battery. It was too wide (rectangular shaped) to fit in the harness. I went to the Toyota Dealership and was given battery was square (they looked up the battery by my VIN #) it fit fine and I was able to change the battery. The car started right up!
    Of course, new issue. I have constant blinking light that I have never seen before, even after i pull the key out. Its a flashing orange light that looks like it has a key in it. I am going to Google it now, but if anyone has heard of this, please let me know. And, thank you for your help. Before I tackle the display, I want to check this light out as I certainly don't want it draining my new battery.
  19. yawkeyfan
    NH
    Oh, I don't have a smart key
  20. hkgngplugin
    46
    Hong Kong
    Hey, that light tells you you car lock is on. If you move your car with that light blinking, your car alarm should comes up. Btw, it is very amazing to me that you’ve driven your car for so many years, and you don’t recognize that light!
