What can I do with this?
Discussion in 'Gen 3 Prius Audio and Electronics' started by 102mm, Nov 30, 2013.
  1. 102mm
    102mm Junior Member
    30
    Who at Toyota thought that a back up camera was a better idea than back up sensors? This does me no good. I never really used it but just knowing that I can't instead of I choose not upsets me. [​IMG]
    SM-N900V ?
    mtbiker53 likes this.
    51,518
    mine works great, have you had it looked at by the dealer?
  3. DougHeffernan
    DougHeffernan Junior Member
    Have you tried rainx on lens
    Turn off signatures in Tapatalk Tapatalk
    102mm likes this.
  4. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Mine works great, it looks like the lens on yours has been damaged. I use it all the time.
  5. mrbigh
    3,686
    699
    Long Island, NY
    Maybe a water stain?
  6. fuzzy1
    10,337
    Those are not water stains, they are actual water droplets on the camera lens. Just wipe them off.
  7. Grren4ever
    Grren4ever Active Member
    347
    167
    those water droplets are on my lens too but they either get blown off from driving or just dry up. I wouldn't go as far as to bash a car company for having them standard now on the Prius models (at least in canada, they are standard even on the base models)
  8. 102mm
    102mm Junior Member
    30
    OK... Say I'm parked face in a parking space after after driving in the rain, when I go to back out droplets on my lens is not what I want to see. Somebody should have caught this during the design phase. I'm not dependent on it, but if I want to use it, it should be available rain or sun...
    SM-N900V ?
  9. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    Some ideas for the next generation ?;)
    Cristino and Silver bullit like this.
  10. bisco
    51,518
    huh, i've never noticed that problem.
  11. bubbatech
    bubbatech Member
    153
    60
    Alabama
    Make sure the protective film on the lense was removed at the dealer.
  12. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Really? You are going to complain about water on the camera lens?
    Almost all our vehicles have a backup camera and it is just normal practice to walk past the hatch and rub the lens once. Gets the dirt, stains, and water off.
    And the picture you show is perfectly usable. You can see the other cars in the background that are parked, you can see the entire field of vision.
    peterjmc, Skunkworks and uropip like this.
  13. mrbigh
    3,686
    699
    Long Island, NY
    you can have a maid to clean it up for you :rolleyes:
  14. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I'll agree with the OP- having just a camera isn't really too helpful.
    That being said- having sensors and a camera would have been awesome!
    Karis likes this.
  15. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    The camera is awesome, and I now miss it in cars that don't have them. A couple water drops - oh no, it's the end of the world... really? Might have to, gasp, use the mirrors...
    uropip likes this.
  16. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    eh, I agree. since the snow started falling mine has been basically useless, constantly covered with road grime. I suspect a more protected location could have been found.
  17. uropip
    uropip Member
    138
    S.E. MASS
    2013 Prius Plug-in
    My car gets wet when it rains... I think its a design flaw...
    GT-N8013 ? 4
    fuzzy1 and xliderider like this.
  18. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    I know right? Totally unacceptable, what was Toyota thinking? SMH
    SCH-I535
    peterjmc, Scynfewl and uropip like this.
  19. fuzzy1
    10,337
    Where I travel, winter road grime coats the entire rear of the car. The more protected places I can think of, will not provide the required rear view. So the backup cam lens needs to be cleaned regularly, just like the windows.
  20. zhenya
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    Front and rear windows are either protected by aerodynamics (sedans) or they are fitted with a washer. The camera was slapped on the Prius with no regard for either. As a result, it is uselessly covered after just a few miles on winter roads, just as our windows would be if you had no means to wash them on the move.
    A solution could have been found.
