Water spill near hybrid battery vent
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by liscifan, Dec 8, 2013.
  1. liscifan
    liscifan New Member
    Somebody please help me calm down! My toddler spilled a open bottle of water from her rear facing car seat on the passenger side of my brand new Prius III. From what I can make out, her car seat and the sides of the passenger seat took most of the damage. But there were a few drops of water on the spokes of the battery vent. I cleaned it up and tried peering inside the vent to see if water got in but I couldn't tell much as it was dark out. We had to drive it back home as we were 20 miles away. What should my next steps be? Should I take it to the dealer in the morning to have the battery checked out? Can I remove the vent cover and wet vac it?? What signs should I look for? Am I looking at having to replace the battery! I am kicking myself so please be gentle...:(
  2. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    By all means get the dealer to check but it's highly unlikely that any damage was done. The actual battery is quite well buried and water, the small amount you describe, would only get to the battery if the fan was operating at a high enough speed to spray it into the battery cavity. Even then things are well insulated in there and short of flooding the whole compartment, it would be difficult to do a lot of damage.:)
    Additionally, it is highly likely that the warmth in the battery compartment and the air movement occasioned by the fan would have dried any remaining moisture.
  3. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    I would also suggest that you keep a small reliable torch (flashlight) in the car. You never know when it might get you out of real trouble.
    Perhaps also some other bits and bobs but I will leave their suggestion to others in the US more familiar with your location.
  4. liscifan
    liscifan New Member
    Thanks for the reassurance, feri. I hope too much water didn't reach all the way to the battery. Is there anyway to tell?
    I forgot my phone can be used as a flashlight, IanIanIanIan! I think my brain froze in the panic. But a dedicated torch is a good idea.
    Thank you-feeling a little hopeful that it wouldn't have caused too much damage.
  5. Former Member 68813
    3,524
    983
    US
    Not knowing your location, I'm not sure what you mean by "torch", it means different things in different countries.
    I personally would not report it to the dealer. I would be afraid of the "warranty void" stamp in your books.
    BTW, I have one of these products and it works very well keeping things dry and free of mold (in my boat in very humid climate): Portable Dehumidifiers | Eva-Dry
  6. Mendel Leisk
    41,244
    I doubt there's any problem.
    First off, the fan behind that vent runs at various speeds, perhaps off much of the time. With a near-new car it's not likely it was running at high speed.
    Also, when the water spilled it likely just ran down the spines of the grill, nothing more. Behind the grill is a duct that leads to a barrel shaped fan, and from there air is blown across the top of the battery.
    If the fan was running, any drops, if they made it through the grill, just clung to duct surfaces somewhere along the route. And the cells themselves, at the battery, are plastic cased.
    To see what's happening directly behind the inlet grill, there's a single bolt, between the seat and back cushions, reachable with a ratchet wrench with extension (think it's 12 mm socket). Once that's removed you can pull out that portion of the seat back, with grill off. There's a few hooks on it that need to be wiggled off.
    You can also pull up the hatch area floor panels. There are a lot of tenacious fasteners. I took a look at ours, and left half of the fasteners out when reassembling, and it's still very secure.
    Here's a few pics of what it looks like:
    (the white material is over the inlet grill, acting as a filter)
  7. Feri
    Feri Active Member
    761
    144
    Liscifan, I think Mendel Leisk's photos should reassure you. Short of flooding there is little risk of the water reaching the battery. The filter is something of a personal choice. Some owners, particularly pet owners or taxi drivers, have found that the fan can get clogged with dust and fur. I have dismantled my fan(again recently at 100,000miles) and other than a small amount of dust my fan was clog free ( I live in a rural area and do a substantial amount of dirt/dust road driving). The filter will reduce the amount of air the fan can pull in and push over your battery, so unless you do carry pets or lots of people with clothing that sheds lint my personal choice would be to not install a filter.
  8. Feri
    Feri Active Member
    761
    144
    Hi friendly, a torch is what you US'ns strangely named a flash light, even though they rarely flash. :D
    mmmodem likes this.
  9. liscifan
    liscifan New Member
    Thank you so much for the reassurance and pictures too! I haven't had time to look at it in detail yet-dealing with a stomach bug in the same toddler. Ugh..eventful weekend! But thanks to you all I can sleep better than I did yesterday.
  10. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    friendly_jacek,
    I am in the UK exactly as my profile mentions.
    I well know that The English language is mangled by others around the world which is why I put the word 'flashlight' in brackets after my mentioning a 'torch' so there would be no doubt.
  11. liscifan
    liscifan New Member
    Thank you for the pictures, Mendel Liesk. It helps to understand how well protected the battery is. I am way too chicken to open it up myself. So I am going to skip that.
    friendly, I didn't end up taking it to the dealer because I was worried they will use it as an excuse to void the warranty. Thanks for the link to the dehumidifier.
    Thanks everyone! I hope the incident didn't cause too much damage- atleast I learnt a lesson-think twice before handing over food and drink to ur kids!
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Always wondered about that. What do you call a torch then? The actual flaming kind.
    Anyway, I hand my toddler drinks all the time in the backseat. If you think a bottle of water in the backseat will take out the battery, you have too few thing to worry about. The chances of a bottle of water hurting the battery through that vent is zip. The most I worry about is my daughter dumping the milk all over the upholstery.
    Turn off signatures in Tapatalk Tapatalk
  13. Feri
    Feri Active Member
    761
    144
    Umm, the flaming kind we call a torch.;)
    mmmodem likes this.
  14. mmmodem
    2,732
    1,703
    Bay Area, CA
    I don't know. A flashlight doesn't flash often but it can. But when I ask for a flashlight and I get a flaming torch because it's the same word...? Sounds weird to me. Just like "penny wise, and pound foolish." But eh, we can go on forever about why American English is different than British English.
  15. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    The thing I have been wondering is if you can stick one of those minicam-lights down there to check on the the fan. Which in a Gen2 the fan can get clogged. I noticed Walmart was selling those cam/lights for $50 I was tempted.
  16. Feri
    Feri Active Member
    761
    144
    No one still sells flaming torches, even here in the backward Antipodes. Though we may occasionally use the vernacular "Give us a flamin torch will ya mate!".(y)
