2010 Prius P2237 O2 Sensor Code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kc1984, Dec 13, 2013.
  1. kc1984
    kc1984 Junior Member
    My check engine light came on in my 2010 Prius III so I hooked up to a scanner and the following code came up:
    P2237 O2 Sensor
    Positive Current
    Control Circuit
    Open - Bank 1
    Sensor 1
    My car has close to 60k miles so I don't think this would be covered under warranty. I don't know if this is related to this code but recently my exhaust smells kind of like bleach/chlorine.
    I tried checking around on this site and google but didn't find much information. Has anyone had the same code pop up? How did you fix the problem? (What part did you replace, did you DIY or have dealer do it)
  2. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    FYI - Here's some information to keep in mind if you start to troubleshoot the code.
    It's related to other Toyota cars with the same code.
  3. kc1984
    So if it is a faulty wiring harness would this be covered under warranty?
  4. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    There is no TSB for Prius.
    Like the article said "Test the devices in question" if they are good then it could be something else.
    The next thing to check is the wiring. That problem has been seen on other Toyota cars with the same code.
    More than likely the mechanic will want to replace the o2 sensor.
    If the light comes back after you replace it you can point to this article as the next thing to look at.
    Someone on prius chat with an earlier model had the same issue trying to fix that code and could not get it fixed after the o2 sensor was replaced many times. Search this website for the code and read his ordeal.
  5. kc1984
    How do you test the O2 sensor? Is there a special tool needed?
    When you say check the wiring could it be there is a loose wire or something like that?
  6. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Here are things to look at under Possible causes:
    It's all I got, hope it helps.
    P2237 Toyota Oxygen (O2) Sensor Positive Current Control Circuit / Open (Bank 1 – Sensor 1)
    Possible causes
    - Faulty Heated Oxygen Sensor Bank 1 Sensor 1
    - Heated Oxygen Sensor Bank 1 Sensor 1 harness is open or shorted
    - Heated Oxygen Sensor Bank 1 Sensor 1 circuit poor electrical connection
    Symptoms
    - Engine Light ON (or Service Engine Soon Warning Light)
    P2237 Toyota Description
    The linear O2 sensor is mounted on the front side of the Catalytic Converter (warm-up catalytic converter) or in the front exhaust pipe. It detects a wide range of air/fuel ratios in the exhaust gas from the rich to lean regions. This linear O2 sensor produces a current that corresponds to a specific air/fuel ratio. The Engine Control Module (ECM) monitors this signal and determines whether the air/fuel mixture is rich or lean. The ECM constantly monitors the linear O2 sensor and increases or decreases the fuel injection duration using this signal. This is called closed-loop fuel control operation.
    CloudJumper likes this.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    The DTC codes that I have specifies the Air-Fuel Ratio Sensor 1 which is the one upstream of the Cat Converter.
    P2237
    Oxygen (A/F) Sensor Pumping Current Circuit / Open (Bank 1 Sensor 1)
    - Open in air fuel ratio sensor (sensor 1) circuit
    - Air fuel ratio sensor (sensor 1)
    - ECM
    There are a variety of codes for the A/F Sensor for a variety of problems. This one is specific with an open circuit. It sounds like replacing the sensor would be a good first step. If you can disconnect the connector and test the sensor for open circuit this would help determine if it is the sensor, the connector or the cable.
  8. jdcollins5
    5,131
    1,342
    Wilmington, NC
    The Repair Manual indicates an open circuit between terminals A1A+ and A1A- which is the sensor signal to the ECU.
    P2237 (Air Fuel Ratio Sensor Open Circuit Between A1A+ and A1A-)
    Air fuel ratio sensor admittance Below 0.002 1/Ω
  9. mrbigh
    3,686
    699
    Long Island, NY
    you found your culprit....
  10. kc1984
    So would replacing the sensor fix the problem or is there more to it?
  11. jdcollins5
    5,131
    1,342
    Wilmington, NC
    The sensor would seem to be the most likely candidate. A loose connection or broken wire could also cause the open circuit. So there are multiple possibilities here.
    If it were mine, I would disconnect the electrical plug to the sensor and check the resistance between the A1A+ and A1A- terminals. If I read an open circuit with a multimeter then that would indicate the sensor is faulty and I would replace the sensor. If the sensor read something greater than 0.0021 ohms then this would eliminate the sensor and I would begin checking the circuit connector and wiring back to the ECU module.
    The dealer tech should follow the Repair Manual procedure which includes testing the resistance of the circuit. Most dealers that I have dealt with in the past prefer to replace parts first and then troubleshoot the problem further if this does not resolve the problem. You still have to pay for the replacement part even though that does not fix the problem. Most electrical parts are non-returnable.
  12. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    Different vehicle, but this video may put you on the right track:
    SFO and jdcollins5 like this.
  13. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Nice video.
