Can you turn the traction control off in a Prius C? :cautious:
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by tgpii, Dec 9, 2013.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
  2. fourenty
    fourenty Member
    46
    25
    Endwell, NY (near Binghamton)
    2024 Prius
    Limited AWD-e
    Yep, I'm not sure how. Someone posted the procedure. Do a search for it. I'm sure you will find it.
  3. lunas_lass
    lunas_lass New Member
    28
    Grand Mound, Washington, USA
    Wouldn't recommend it. My C 4 did just fine takin easy on the ice and snow...
    It's a lot of shift this and jimmy that; grateful I have not needed to disable it.
    All the best from Luna's Lass!!
    ...? via my Samsung Galaxy S2...
  4. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    look in your owners manuel, I remember reading about it. I think you just push a switch on the dash and it turns it off for a short time. I think the only time you want it is if you are stuck and want to be able to spin the tires to get out. My little C does great on slick roads. much better than I thought it would
  5. lunas_lass
    28
    There's typically a switch however with 12 prius C there isn't. :(
  6. Snowball
    Snowball Junior Member
    48
    Southern CA
    lunas_lass likes this.
  7. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    It can be done. I used it last year. The procedure to start with the control off is a pain, but not difficult.
    The BIG thing to remember is this...you have to be a person that can press gently on the gas pedal to slip your tires through a traction problem at the slowest possible slip rate. You absolutely can not mash the gas and power through an intersection. To do that would be the death of your transmission.
    If you have an educated foot, go for it, but if you are a mash-and-pray person...forget it.
  8. xraydoug
    571
    176
    Roseburg, Oregon
    I have a C2 and I have a key what is the procedure to shut off trac control on it? I until last night thought there was a switch on my dash. that is what our 2012 camry has. the 13 C2 has not switch I could find
  9. fourenty
    fourenty Member
    46
    25
    2024 Prius
    Limited AWD-e
    Go to the link provided in a previous post.
  10. tgpii
    tgpii Member
    382
    63
    I was just wondering. I do use the low gear (B) in the snow and can feel the difference. The low gear (B) on a CVT seems to work better then the low gear (1) (2) on a typical automatic.
  11. HotDogWater
    HotDogWater Junior Member
    70
    17
    It's not a lower gear - it just provides more braking when you let off the gas pedal.
  12. xraydoug
    571
    176
    Roseburg, Oregon
    Thanks, I will go back there, however I looked at it before and I saw a description of how to do it on the c3-c4 that have the push button on the dash instead of the key. I will go back because I didn't check to see if there were more than one set of instructions. :)
  13. Snowball
    48
    Southern CA
    This is one of the post in the first thread I linked: Disable Traction Control for winter situations? | Page 2 | PriusChat
    I think you just turn the key to "ON" without starting the engine and follow the directions.
  14. lunas_lass
    28
  15. butterball
    butterball New Member
    2014 Nissan LEAF
    There are typically about 5 steps to turning off a Prius C from what I have seen in the past, and I only know that because my friend owned a Toyota, I remember my friend mentioning one time, how the steps to turn it off had to be done within 60 seconds when starting their car. The funny thing though seems to be that most people forget they do not have to go to an auto shop to do this and that they can do it on their own saving some momey if they know how and do not mind following the steps each time before they start their car.
  16. fourenty
    fourenty Member
    46
    25
    2024 Prius
    Limited AWD-e
    Snowball was replying to someone who has a key. We all know some PC owners do not have a key.
    Nexus 7 ?
  17. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    and we all know that we all have an "ON" position. I'm not sure why he commented on it not having a key either...
    Snowball and fourenty like this.
  18. fourenty
    fourenty Member
    46
    25
    2024 Prius
    Limited AWD-e
    True
    Nexus 7 ?
  19. Snowball
    48
    Southern CA
    Yes, I was replying specifically to his post which is quoted where he doesn't have the push start, but uses a key instead.
  20. lunas_lass
    28
    You guys can give it a rest now. It is getting annoying. I said that tongue in cheek.
    tgpii likes this.
