Upgraded to 17" OEM Prius Five Wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Sushi_1001, Dec 14, 2013.
  1. Sushi_1001
    Sushi_1001 Junior Member
    77
    Hi All,
    My 15" stock tires (2011 Prius Two bought brand new) were worn out at 28,880 miles. I had balanced, rotated, and aligned them every 5,000 miles. I don't know if these are maximum mileage one can get.
    Anyways, I have upgraded to OEM 17" wheel from a Prius Five model with Pirelli P7 tires, 215/45/17. These tires have a thread wear of 700 UTQG, rated at 91V and warranty of 70,000 miles, they are also LRR tires.
    They have received goods reviews on tirerack.com.
    Consumer Survey Results By Category
    Tire Test Results : Testing Grand Touring All-Season Tires with a Sporty Edge
    Got them at my local America's Tires for $640.00 out the door.
    I'll give a review later on the tires, on how they feel, handles, comfort, mpg,etc... image.jpg
    oalvarez likes this.
  2. AllanM
    AllanM New Member
    Looks good, I may have to upgrade to the 17" wheels.
    - Allan
  3. toyopri808
    toyopri808 Active Member
    226
    116
    looks great!
  4. xliderider
    xliderider Senior Member
    8,054
    3,221
    Honolulu, HI
    Very nice, you're lowered as well? Or is it the incline of the driveway and resulting weight transfer making the front well gap smaller? :p
    SCH-I535
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Low tp may have shortened your 15" tire life. If you run stock pressure in the 17" tires you'll chew them up as well.
  6. Sushi_1001
    77
    Thanks for all the kinds words.
    Not lowered , it must be the incline on my drive way.
    I had 38 psi on my stock 15", what psi should I run my 17" tires, 38-39 psi?
  7. Mendel Leisk
    40,562
    I'd run the 17's a little lower, the ride is harder.
    You're very slightly lowered: the od of the 215/45R17 is very slightly less. ;)
  8. Sushi_1001
    77
    Really, stock recommendation I think it's 33psi F and 32 psi R.
    Should I follow the recommendation at 33psi F and 32psi R?
  9. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    I ran my OE 17" tires at stock pressure and got over 70k miles out of them (rotating every 10k). I consider that pretty good as the factory tires on my RX350 lasted only 30k.
  10. Mendel Leisk
    40,562
    ^ Sorry for the funky quote. I'm using IE11 browser and the site's not working well with it.
    Ours has the 17" stock. I usually run them around 36-38. With 195/65R15 I'd go higher, around 42. But the low profile 17's have a firmer ride. It's your taste really, but I've found the ride really harsh any higher, especially going over speed bumps (which I hate...).
  11. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I would be interested in hearing what your mileage impact is.
  12. Sushi_1001
    77
    Sure, I'll post a update after my first tank. It may take 2-3 weeks, my work is less than 6 miles from home, all local with no hills or slopes pretty even coasting.
  13. Mendel Leisk
    40,562
    The Pirelli P7 sound like a very interesting new tire choice, in 215/45R17.
  14. Sushi_1001
    77
    They come in 205/50/R17 too, for those who wants to match the same diameter of 195/65/R15 wheel and tire size.
    Link to 205/50/17 Size:
    Pirelli Cinturato P7 All Season Plus
  15. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
    I'm due for some new tires. How are the Pirelli's holding up?
  16. NickInNJ
    NickInNJ Junior Member
    61
    New Jersey
    factory size tires on 17's are 215/45/17
  17. Sushi_1001
    77
    GREAT!
    I have them for 14,000 miles and they still look brand new. I had the Pirelli P6 in my previous vehicle and I loved them. Therefore I went with the P7 and they did not disappoint.
    Here are reviews on tirerack.com
    TireRack.com Tire Reviews
  18. Mendel Leisk
    40,562
    Thanks Sushi. Any impressions re rolling resistance?
  19. Sushi_1001
    77
    Hmm, I'm not the best one to answer this. I only live less than 6 miles from work with no freeway driving and pretty even roads. I get an AVG of 45 MPG but I definitely don't drive like a Grandma or drive cautiously to improve my MPG. I also have a "Curt" hitch and European Mud flaps, I don't think these are help my MPGs.
    You're in Canada, I'm in California, so I have no experience with these tire in the snow.
