Got charged $1500 repair costs for fueling diesel into Prius 2013 4D (Zipcar)
Discussion in 'Fred's House of Pancakes' started by Nymous, Dec 14, 2013.
  1. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    Auto diesel and gas use the same size filler nozzles.
  2. Air_Boss
    Air_Boss Senior Member
    4,197
    1,182
    New Yawk
    JMD likes this.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I thought it was universal. Same rule applies here and has for the last 25 years or so too.
    Are your fuel pumps colour coded too? Unleaded pump hoses and nozzles are green and diesel ones are black. The old leaded fuel ones were red or red and black (though leaded disappeared 13 years ago).
    This link shows a regular Shell petrol pump with 4 options; 2 diesel options (normal and super diesel) and 2 petrol options (premium 95 and super 98). Diesel is black and petrol is green.
    http://www.dailymail.co.uk/news/article-2150469/Shell-introduces-petrol-pump-attendants-recruits-staff-300-forecourts--check-tyres.html
    Bet you didn't know that there are two types of diesel fuel! Also notice that the Audi convertible in the article is a TDI.
    As diesel cars and diesel fuel becomes more common in the US, you're going to have to introduce a similar system to avoid misfilling.
    What happens if I put petrol in my diesel car? - Telegraph
    Put the wrong fuel in your car, petrol in a diesel? Call Auto Fuel Fix.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I'm pretty sure that here in the US gasoline nozzles are usually black and the few that have diesel color those nozzles green, making it the opposite of what you've observed for the UK. They tend to also set the diesel nozzles quite apart from the 3 grades of gasoline we normally have, making it harder to make a mistake.
    A quick Google search turned up Green nozzle handle diesel? Not always! - TDIClub Forums where it seems there really is no standard.
    I don't get gas much anymore (sometimes, once every 2 months or so) as I mostly drive my Leaf now. Free charging at work helps. (y)
  5. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    Same here!
  6. El Dobro
    El Dobro A Member
    7,088
    3,270
    There's at least three different size nozzles for diesel in the US. The big ones are usually high speed for filling truck tanks.
  7. Air_Boss
    4,197
    1,182
    New Yawk
  8. massparanoia
    697
    467
    Virginia
    Maybe I'm thinking the other way around, we've had new EMT's put gas in the ambulances before.
  9. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Expensive mistake? - sure. A life threatening event (IE: injuries or worse) - no.
    Be blessed it could have been worse. You are able to walk away and go on with your life.
    You have gained some wisdom and knowledge.
    That, is a good thing.
    DBCassidy
  10. Air_Boss
    4,197
    1,182
    New Yawk
    No placards on the tank caps?
    diesel fuel only decal - Google Search
  11. danvee
    danvee Blizzard Brigadier
    326
    53
    New Jersey
    I think post #14 pretty much says it all.... Took 2 people.... :rolleyes:
    jhinsc likes this.
  12. bisco
    51,883
    according to a recent audi commercial, a woman was able to put diesel into what everyone though was a gas car.;)
  13. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    I'm pretty sure all vehicles have a sticker on the inside of the fuel filler door specifying what type of fuel to use. ;)
  14. Air_Boss
    4,197
    1,182
    New Yawk
  15. massparanoia
    697
    467
    Virginia
    Oh yeah. Everything short of a neon sign. Not all the diesel pumps here have green handles. And when you're fueling up after a busy 24hr shift...
  16. El Dobro
    El Dobro A Member
    7,088
    3,270
  17. hkmb
    hkmb Senior Member
    279
    1,855
    Sydney, Australia
    Would this not be covered under the standard damage waiver with a rental? I'd have thought you'd just have to pay a few hundred dollars in excess. Or is it different there?
    GrumpyCabbie likes this.
  18. orenji
    orenji Senior Member
    5,887
    3,488
    Diesel? Have you ever driven a diesel car? Have you rented a Zipcar before?
  19. danvee
    326
    53
    New Jersey
    Only if you pay for it.
    Our local Enterprise RAC calls it the "steering wheel and keyring" insurance : so long as you bring both back, you're good. :)
    No deductible...
    Don't know if it would cover this....
  20. Feri
    Feri Active Member
    761
    144
    Yeah we got those too!
