Help! Hatch will not open....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FrankD, Dec 14, 2013.
  1. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Hello all! I have a 2007 Level 3 Prius with about 110k miles. I now have a problem that I am not sure how to fix.
    We moved to central Florida a few years ago and perhaps because of the warmer weather the rubber that you press to get the hatch open has gotten kind of sticky. Sometimes your fingers will get some sticky black on them. I was starting to think that I should look into replacing this rubber. The hatch was sometimes getting hard to open.
    Well, we just took this big 1300 mile drive from central Florida to western NY. We are now in 9 degree weather. I cannot get the hatch to open at all. The other day it stuck but after a few attempts and carefully pressing down on the hatch without hurting the spoiler I got it to open. I first thought it was just because things were packed tightly, but now nothing is back there and I cannot get the hatch to open.
    I think I have resigned myself to the fact that I wont fix this until I'm back in sunny warm weather. Any thoughts on how to get this to open? And if I do get it to open will I be able to close it again? It feels like there is no longer any "give" to where you press the rubber to open the hatch. Any help would be very appreciated!!
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    my rubber part dried out on me (2007 Prius) - Toyota replaced it under warranty. The new rubber piece feels quite different than the original one. Your car is out of warranty, but you can always try to get them to replace it with the notion that it has been this way for a long time. I believe the cost is around two hundred dollars.
  3. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
  4. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Thank you SO MUCH for this info! I am currently up here in Freezing NY, so when I get back to sunny warm Florida next week I will look into this. You are correct....this switch cover IS all melted. Perhaps this is just a fluke that this happened when we got up here...I was hoping it is just frozen and it would start working again when I got back south....but the switch does seem like it does not move at all.
    I really need this to work, as I now use this car for my Home Inspection business and keep all of my ladders and tools in the back. So.....maybe I can get my dealer to fix this. If not, because this forum saved the day again worse case I can fix this myself. Any additional info is appreciated....I will keep you all posted!! Thanks, Frank D.
  5. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    OK....I have a dumb question. I just read the very good thread on this subject, and to fix this they say the first step is to open the hatch. SO.....if my hatch cannot open how do I open the hatch to fix this? Is there any other way to get the hatch open of the rubber switch is not moving? Thank you in advance for any help.......
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    There is a mechanical latch inside the trunk. You have to fold the rear seats down, clean out whatever is in the trunk, and crawl back there. If you've got an 8 year old kid available, it will go a lot easier...
    I think the latch is documented in the owner's manual. If not there, then certainly in the service data.
  7. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    This is for GEN II, but newer are probably the same.
    It's time to be Houdini.
    Use your metal valet key to open the driver's door if you have to.
    Inside the back of the car, in the spare tire compartment there's a small black panel in front of the hatch latch about 1 1/2" x 3".
    Have to lower the back seats, take out the carpet in the back, then unlock and remove the hard cover for spare compartment to get to it.
    Not easy to do when you're doing it from the inside.
    Push the release on one end of the panel and take it out.
    There's a manual hatch release in the space.
    You can use that to open the hatch.
  8. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    on my car, it was hard to open the trunk on cold mornings, but once it warmed up it was easy.
  9. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Thank you all! I will wait until the weekend when I'm back in Florida and do this if I need to. Thanks again!
  10. Patrick Wong
    18,210
    6,510
    My thread may be of interest to you:
    How to Replace the Hatch Opening Switch | PriusChat
    There is no way that your dealer will fix this problem without charge since that part is covered under the 3 year/36K mile warranty.
  11. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    my 2007 Prius trunk repair was fixed under my 100k extended warranty - my car had 95k miles on it - it was repaired last year 12/27/2012
    The serviceman looked at it and was probably trying to tell me they wouldn't, but I told him every year it was getting harder and harder to open and now the rubber part is all cracked - then he said yes to repairing under warrant.
  12. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    I spoke to Toyota customer service and now have a case number. They told me to check with the dealer and find out the cost. The part with the smart key option is $57. and the labor is $142, so the total cost would be about $200. I'm over my extended warranty but since I told them truthfully that this has been a problem for awhile and most likely due to a bad batch of switches made in late 2006 they told me they may be able to cover some or all of it. Online I can buy the part for around $44. so worse case, I could do it myself next week when I return to Florida. I thank you all for your good info and I'll keep you posted. I feel like I came late to a party everyone else knew about, as this seems to be a common issue.
  13. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    The charge for Toyota to repair this last December was $242.06 plus tax.
    $97.06 for the part (84905-47010) and $145.00 for labor plus tax.
    Not sure if they replaced just the plastic part - the name of the part is Switch Sub-assy
  14. Patrick Wong
    18,210
    6,510
    That part includes the rectangular hatch opening switch as well as the little squarish Smart switch.
  15. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    They probably replaced the whole assembly, Smart Key switch and the small button assembly on the side, except for outer shell.
  16. FrankD
    FrankD Member
    199
    40
    Leesburg Fl.
    Ok...here is an update. Upon returning to warm weather, the hatch switch started working again with no problems. Of course, it is still somewhat gooey, but it works. Toyota customer service told me to go get it fixed at the dealer and then they would review perhaps covering all or part of the repair.
    I went to the dealer this morning. They started to fix it, but then ran into a problem. The three screws holding the smart switch part were rusty and could not be unscrewed. They told me that I would now also need to replace the long plastic piece the switch mounts on and the new cost would be around $400.00
    I told them that they could use the non-smartkey switch and leave the screws alone and just splice in the two small wires. They replied that they did not know how to do that and it was not an option they would be comfortable with.
    So.....after being there almost 4 hours we decided to not spend $400.00 They charged me $56.00 diagnostic fee and left the interior trim and the plastic piece off. I am currently soaking some PB blaster on the 3 screws. At this point I will either get those screws off and buy the switch myself and fix it or just put some Gorilla Tape over the gooey rubber part, replace the two license bulbs, put it back together and never drive up north with it in the winter. Oh well....
  17. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    Hope the PB Blaster works. If they don't reasonably come off, here is a pdf on how to replace the switch with a splice.
    In case you have to replace the garnish, part number for the Back Door Outside Garnish Sub-assembly with Smart Key is 76801-47060-A0 for super white. Cost about $146. Last part changes for color, B0 for Silver Metallic, B1 for Gray ME, C0 for Black, D0 for Red, E0 for Bronze, G0 for Green metallic, J0 for Blue MC, J1 for Blue M.M.
    FrankD likes this.
